I’ve had a couple PM’s asking about balancing with the 6S-8AH battery pack. I went the route of purchasing two 3S-8AH batts (CNHL 3S-8AH-30C) and wiring them in series, to get 6S voltage and 8AH capacity. I’m parallel-feeding both 5055 motors from this pack. To balance at the manufacturer’s suggested CG location of 175mm aft of the leading edge, I had to push the battery pack as far back as it’d go in the battery compartment. I’m still about 5mm nose heavy, but plan to maiden with this slight nose heaviness.
I ‘ve got her loaded and ready to deploy. Once I get to the field, I’ll do a thorough range check, recheck the wiring and kick the tires. If no problems are encountered, I should have her in the air in a few hours. :-)
I’m a getting a bit nervous, I have to admit. Maddening small stuff doesn’t phase me anymore, but maidening large, complex warbirds still turns my stomach in knots.
