Freewing P-51D HP "Old Crow" 1410mm
  • Freewing P-51D HP "Old Crow" 1410mm
    Hi all,
    anyone had this problem, if so what did you use to stick the loose servo down with?
    Thanks
    Chris
    DRCH
    I use FoamTac. Clean off as much as possible, of the original white glue from the servo first. Use a razor blade being careful not to slice into the wires.
      Some FoamTac will hold that. Alternatively, low temp hot. glue will also work well.
        Thank you, wanted to make sure. Will give it a go.
        Chris
          FoamTac is the best glue for gluing foam. It stays flexible and will move with the foam. Epoxy or any hard setting glue will break at the joint because it can't flex.
            Will do thank you. Nice that you was with a real Old Crow.
            Chris
              I can only claim to have stood in front of the Old Crow and NOT flown it.
              PappaBear
