Waiting on reports about how good the power is (unlimited vertical?) and if there is flex in the fuselage like one of the very early Motion videos showed.
Come on guys, it's Thursday already! :)
Check out my video a few posts back from the tail boom. See what you think yourself on wing-flex. Yes, if you pound it to the ground or pull high-G maneuvers there is a little flex but nothing crazy. It does not have unlimited vertical, it's not a T-33 on 6S power, but get the momentum up before pulling vertical and you'll get some satisfying height. I enjoy pulling vertical and then using max rudder to u-turn it right back around making a u-shaped pattern over the field.
He's asking about fuselage flex, if you don't mind my interjection...
There has been some confusion on how to wire the flaps using the provided tri-harness. The two outer flaps come into the blue MCB box through the ribbon cables. You take the male to male out put from the blue MCB box and insert it into the tri-harness instead of going straight to your RX. You then take the two inboard flap connections and also insert them into the tri-harness before running it straight to your receiver. In short: take all three cords labeled FLAP, insert them into tri-harness, and go straight to the RX with it.
Sorry, I misunderstood. The fuse is a very solid piece of foam, ain't no flex there for sure. BUT..... with 2X 4000's in there the fuse has some weight and does bounce up and down a tad (see the video from the horizontal stab) between the booms. This is not a 3D plane guys but with so much side profile it does knife-edge well. If you're going to add a ton of power and attempt Timber X like 3D you will want to shove a carbon rod between the booms out back and triangulate it with two more carbon rods going into the abdomen. Just my 2-cents on that topic.
Mine arrived today. No surprises, the components are perfectly packed in a 2-part styrofoam box just like all the other MRC planes so everything is in perfect condition. Of course.
ALL PILOTS TAKE NOTE OF THIS INSTRUCTION. Spent a few confusing minutes figuring this out as well. I wish I had seen this post first and I wouldn’t had been struggling and wondering what I was doing wrong. Boomer senior moment. 🤪
Thank you so much Alpha, MRC, and Flightline for this beautiful airplane, it is everything I hoped for and more. I can't wait to get it assembled and out to the flying field.
Got my Bronco yesterday and getting ready to install the Admiral RX6000SP Stability Plus receiver. Have everything hooked up (thanks for tip on Flaps) except for the throttle leads. Not totally sure where the throttle leads go. Pretty sure the double lead marked throttle goes to the throttle port on the receiver but not sure where the lead marked throttle coming off of the UBEC plugs in. Thanks for any assistance.
Are you sure it's marked "throttle"? I don't think that's a throttle lead. That's likely a power lead that plugs into any empty port on the RX or you can "Y" it to any used port. It provides power to the RX.
Yes they are both tagged "throttle". I also think it is a power lead as it is coming off the UBEC, but it never hurts to check with the group just to be sure.
Pilots! Our CS team is getting lots of questions regarding how to setup the flaps on the OV-10. So I will 100% make a video doing it again although you can see me do it on our live show here: https://youtu.be/P54ud8NdwT0?t=4179
But, I whipped up a quick diagram that explains it. Basically, you are supplied the 3-way servo extension for the flaps. You will have both inboard flap leads connected to the center wing section, so plug each end of those into 2 of the 3-way extension slots. Then, your outboard flaps signals are sent into the blue box via the ribbon cable, so take the flap lead coming out of the blue box and put that into the third open slot on the 3-way servo extension. Then plug the single end of the 3-way extension into your flap port on your RX
