Question for anyone using the Spektrum ar637T receiver, do you also have the remote receiver attached as well?
Originally posted by walkerm45 View PostI here some wh,,,,,,,,,g about the plane. It performs to the design specs. If you want something else, based on your needs, have at it, as that's called modifying, don't blame the plane, as it has taken years to get this baby. Remember the alternative in ths particular size plane....Stop complaining...
Sounds like this plane is a lot like the P-38. Only difference is in the P-38 all I had to do was change the props and drop in a 6s. If they had gone with the same power setup as the P-38 I would have bought one and gave it the same treatment. But after reading about it now I’m glad I stayed away. Maybe it will get a V2 treatment someday and go 6s capable. I’ll get one then.
Gravy
Originally posted by Wild Man View PostIf you have it use it. All the receiver's that I have I use the Satellite receiver's on the larger the plane the more I use. Some of my large gasser's have three remote satellite's in them
I ordered one today. I’m having huge frame losses on my AR637T. Horizon sent me a new one. They also suggested I try range checking other planes with Spektrum receivers. 300 in the first range check, 688 on the second and 733 during the first and only flight.
Just finishing up my OV-10 and I noticed after throttle calibration that one engine brake is on and one is off. So went into the esc set up to set brake off and the opposite side is now off and the other side is on I even went to factory default setting but it did not change the problem. This is my first twin and not familiar with this problem. Any advice would be appreciated.Thanks
Originally posted by KC8REH View PostVery disappointed in the OV10. 2 flight the second one lastni maybe 20 seconds before it was lost due to loss of aileron control. $578 lost total after rebuilding after crashing on the maiden with the Same loss of aileron control. Not shure if I can justify money for a second model.
is anyone who has been having successful flights using the AR637T?
Really sorry to hear of these crashes, that sucks. I'd like to pipe in and say that I have had a few dozen flights in the past few weeks and I love the way it flies, I'm happy with the stock power (and I have no "relationship" with Motion other than I am a customer).
Can I say that there are some RC pilots who overly rely on (or simply prefer) inappropriately huge amounts of power? <Present company excepted>
Don't misunderstand, I enjoy flying fast. My red HK ME163 with a 4-cell goes around 125mph, I love screaming around with that thing and using the rocket. Its fun and appropriate for that model, I think. But I don't fly my B24 that way. Naturally there's no problem with anyone modding to bump up the performance, that's all good fun. All I'm saying that the OV10 doesn't need it to fly well. I can do loops all day (without firewalling it) and I can fly for more than 10 minutes (Admiral 3600's), mostly on medium power settings. It sips those electrons! When I'm flying slow I just use the takeoff flaps and I love doing lazy figure-eights around the field about 10 feet up. Flaps slow it down big time - and its 100% true that you can't fly it too slow, you do need to add power in a slow turn just like XViper said. Just my opinion, I think it flies very well as designed. I agree it would have benefitted from larger props and more powerful motors. But then it would fly for only 6 minutes instead of 10, and would need larger batteries which would make it heavier and things would start breaking.... There's always a tradeoff.
I'm thinking of trying a pair of 2500's, the lighter weight may help the performance and still provide long flight times, since the engines won't have to work as hard. We will see.
I'd like to mention that last weekend the retracts on my Bronco became intermittent, one of the mains wouldn't come down. I cycled it about 10 times in the air and finally got three green - and landed. When I put the plane away, I retracted the gear and then all three of them stopped working. Afterwards I found that all three connectors for the gear were not completely tight in the connector sockets. How could that happen? its a pretty large pile of wires and I think maybe it was pulled around a bit when the tray was installed into the fuselage. I am thinking that perhaps one of KC8RCH's aileron connectors may have pulled out? Don't know of course. But I decided to secure the connectors so they can't loosen or come out. On Sunday I spent a little time making the wires neat to clean up the wiring compartment a bit as well.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Originally posted by boomer108 View PostJust finishing up my OV-10 and I noticed after throttle calibration that one engine brake is on and one is off. So went into the esc set up to set brake off and the opposite side is now off and the other side is on I even went to factory default setting but it did not change the problem. This is my first twin and not familiar with this problem. Any advice would be appreciated.Thanks
If one brake is ON and the other is OFF, you can't go into programming mode while both ESC "throttle" leads are connected at the same time. That will reverse BOTH. (Meaning, you will set the brake ON with one and set the brake OFF with the other.) You must separate them and only program the one that you want to change. IE, you must go find the ends of the "Y" where the two ESC "throttle" lines are hooked up and disconnect the one that is OK. NOW, power it all up and you should hear ONLY the one that you want to change. Go through the steps to get to the brake menu beeps. Lower the throttle when it's time and that should reverse the brake setting for that one. Hook up both throttles to the "Y". Now you should have both of them OFF.
Originally posted by themudduck View PostI'm thinking of trying a pair of 2500's, the lighter weight may help the performance and still provide long flight times, since the engines won't have to work as hard. We will see.
Originally posted by xviper View PostYou got to this point because you tried to calibrate the throttle of both ESCs in a single procedure but you didn't plug in the two batteries fast enough. You plugged one battery a bit too late and the two ESCs began to go into their programming sequence with a slight lag. When you pulled the throttle down, one ESC had already entered the brake ON/OFF menu, so you ended up calibrating one ESC but set the brake on the other.
Thanks Xviper! I was hoping I wouldn't have to pull tray and wires back out but if that's the only way to correct it so be it. Thanks again.
Originally posted by vduniec View Post
I don’t have the wing pylons made yet. Hoping to design and print them at some point. If you’re going to do a Desert Storm bird, you may want to add this. It is the ALQ-144 IRCM “Disco light” jammer. It goes on the bulge on the top at the back of the fuselage.
Here’s the link on Thingiverse: https://www.thingiverse.com/search?q...&sort=relevant
Originally posted by KC8REH View PostIt was Not My AR637T. It has flown sense with No issues.
Originally posted by Jpmcdo View Post
Did you check the telemetry after a range check? I’m going to try a new AR637T. I don’t trust the first one after 733 frames lost. Loss of aileron control sounds like a receiver or transmitter problem. I’m now waiting for basically the whole plane in parts to show up.
