My wife got me this plane and the parts don't match the instructions, as far as I can tell. I would like to know if I put these linkages together correctly. Did I orient them the right way and does it matter? I am new to this and the instructions aren't helping or I am missing parts.
FMS P40B 980mm Built Right?
Originally posted by Johnnyrabuse View PostThey might work but it seems that the clevis are not screwed in enough flaps only require travel down
Originally posted by Hatredy View Post
The servo arm is all the way back and the flaps are straight with the wing. If I screw in the clevis more the flaps will always be down to some degree. Am I seeing this wrong?
Originally posted by boomer108 View Post
There's nothing wrong with the way your control rods are set up. The rods are in line with the servo arm and the control horn and the flap servo arm is in the right position.
You mentioned you got this as a gift... I just want to ask if this is your first RC airplane? I hope not. It generally lacks the qualities of a good first airplane. Wing loading, undercarriage type, size/speed, etc. If you've flown at least another foam electric airplane before, I'd say this one is a good second or third plane.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
- Likes 2
Thanks for the feedback everyone.
