The way it looks in the end the H9 will be cheaper if you're not worried about flaps and the shiny film covering. The H9 is a little bigger, but in the end needs the purchase of retracts if you want them. But you will have to buy those same retracts or something different, as the ones that come with the nexa I wouldn't trust. If you fly off a paved runway they may hold fine, but the grass, I believe the stock gear is on borrowed time. But yes if you intend on upgrading the gear the h9 is cheaper (with the purchase of retracts), but if you plan to keep the stock retracts and hope for the best with the nexa would come out cheaper
Official Nexa 1535mm F6F Hellcat - ARF Thread
I'm set on the Nexa model, my question really is what are the options for drop in retract replacements.
Seems like "Daan VDE" has used the Flightline F4U option (would love to hear how that's holding up)
Then there's the e-flites, but I can't tell if the 25-46 size or the 60-120 size are recommended or would even fit.
It's infuriating we can't get mechanical drawings for most of these things.
this is my f6 with a fms 360kv motor and 15x10 2 blade prop... still have the stock landing gear but have the fms 1700mm f4u gear ordered cause the stock gear will not hold up even off our short grass (only have 2 landings on it so far)
Nexa F6f with 360 kv motor and 15/10 two blade prop. Much faster then yesterday - YouTube
Nexa F6f landing on maiden - YouTube
Originally posted by joshc011 View PostI'm set on the Nexa model, my question really is what are the options for drop in retract replacements.
the landing gear is still okay.
I had to make a small adjustment.
the landing legs are a little too long.
see photo for mod
(small screw of 1cm)3 Photos
no not tail heavy as i used a fms 5060 300kv motor and 4000ma 6s battery .. the fms 1700 f4u retracts are also a bit too long so had to cut some of the bottom of the wheel wells to make the stock tires fit,,, beleave me if dean's mod fits it would be much easer to work with...i will say that the fms struts are very strong though,,i always seem to be chopping up these arf planes lol you would think id be better at it by now
as far as the 9g or 17g servos in the wing i really dont remember what i used but i think it was what ever the manual recommended
I've decided to go ahead and get a bigger motor. This is really messing up the "financial" plan for this airplane, but I just can't bring myself to put 200g of dead weight in the cowling for balance.
She clearly wants a bigger motor, so I'm going to run a rimfire 1.20 with 6s 4000mah battery and a 14x9 3 blade MA prop. I'm also gonna try the Retracts from the F4u 1600. Same as Daan VDE.
AUW should hold steady at 4000g (but without having to add the dead weight for balance)
I just ordered the Nexa Hellcat. I wish it was bigger, but I love the covering and scheme. I am trying to find the right powerplant, but I cannot find the dimensions of the cowling. It says the clearance from the firewall to the prop is 106-108mm, yet the engine that MotionRC recommends (NGH 17cc) has a 113mm distance. Someone put a Saito FG11 in theirs and it fit perfectly at 115mm...and this leaves no room between the engine and the firewall! Some of these airplane plans are so frustrating! I am actually looking at the FG19-R3, but the clearance is 130mm, with a radius of 169mm (6.7inches). Plus it weighs a lot more than the NGH 17. Captains RC has a great video of it with the FG-11 here: https://www.youtube.com/watch?v=Gf9xj0tNbZw and says that a 14 would probably work very well in it. I love his exhaust mod that he does and will probably do it. You can see kind of what is done here: https://www.youtube.com/watch?v=OeVZMG_gbQo. If the R3 won't work (which I doubt it will), then I will go with a 14 if I can find one. I am ordering the E-Flite 25-46 100deg retracts. What do ya'll suggest? My previous experience is my DLE-20 Phoenix Corsair, Dynaflite PT-19 with a DLE35RA, and my TF P51 with a DLE55RA (not completed). I had these planes equipped with engines recommended from friends and I am still trying to learn what is best for what. I have lots of electric experience, but I want to use gas in my warbirds.
