Does anyone have any ideas how to get the flaps to close tightly?
Freewing Dauntless 1400 mm
Re: Freewing Dauntless 1400 mm
I tried everything I knew to get the SBD Dauntless flaps to close tighter from TX adjustments to servo adjustments with no luck. Finally I figured out a way to get both flaps to close tight by securing a magnet on both the top and bottom side of each flap with a small amount of Gorilla glue. The magnets are small and the exact size of the round holes in the flaps. I used one set of magnets on one wing and had to use two on the other to get a flush tight finish. The magnets are strong enough to keep the flaps closed tight but will release when you deploy flaps with your TX switch. This fix also made a big difference in the flight performance of the plane by having a completely smooth wing surface during flight.
RE: Freewing Dauntless 1400 mm
X-Mailer: Microsoft Outlook 14.0
Thread-Index: AQGowNdGz1odcDFzC/BWYR6UDSdYOQEwComWmmTMB4A=
Content-Language: en-us
X-SA-Exim-Connect-IP: 68.230.241.215
X-SA-Exim-Mail-From: roofman1@cox.net
X-SA-Exim-Scanned: No (on sam.nabble.com); SAEximRunCond expanded to false
This is a multipart message in MIME format.
------=_NextPart_000_0045_01CEDFBD.5940E040
Content-Type: text/plain;
charset="us-ascii"
Thanks for the info. Where did you get the magnets?
Roy
[mailto:ml-node+s1075610n1160h74@n5.nabble.com]
Sent: Tuesday, November 12, 2013 2:29 PM
To: roofman
Subject: Re: Freewing Dauntless 1400 mm
_____
If you reply to this email, your message will be added to the discussion
below:
http://motion-rc-community-forum.1075610.n5.nabble.com/Freewing-Dauntless-14
00-mm-tp1135p1160.html
To unsubscribe from Freewing Dauntless 1400 mm, click here
<http://motion-rc-community-forum.1075610.n5.nabble.com/template/NamlServlet
.jtp?macro=unsubscribe_by_code&node=1135&code=cm9v Zm1hbjFAY294Lm5ldHwxMTM1fC
03ODI5NTE5MTQ=> .
.jtp?macro=macro_viewer&id=instant_html%21nabble%3 Aemail.naml&base=nabble.na
ml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble
.view.web.template.NodeNamespace&breadcrumbs=notif y_subscribers%21nabble%3Ae
mail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3
Aemail.naml> NAML
Content-Type: text/html;
charset="us-ascii"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:m=3D"http://schemas.microsoft.com/office/2004/12/omml" =
xmlns=3D"http://www.w3.org/TR/REC-html40"><head><META =
HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii"><meta name=3DGenerator content=3D"Microsoft Word 14 =
(filtered medium)"><!--[if !mso]><style>v\:* =
{behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
</style><![endif]--><style><!--
/* Font Definitions */
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman","serif";}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
color:purple;
span.EmailStyle17
{mso-style-type:personal-reply;
font-family:"Calibri","sans-serif";
color:#1F497D;}
.MsoChpDefault
{mso-style-type:export-only;
font-family:"Calibri","sans-serif";}
@page WordSection1
{size:8.5in 11.0in;
margin:1.0in 1.0in 1.0in 1.0in;}
div.WordSection1
{page:WordSection1;}
--></style><!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]--></head><body lang=3DEN-US link=3Dblue =
vlink=3Dpurple><div class=3DWordSection1><p class=3DMsoNormal><span =
style=3D'font-size:11.0pt;font-family:"Calibri","sans-serif";color:#1F497=
D'>Thanks for the info. Where did you get the =
magnets?<o:p></o:p></span>
D'><o:p> </o:p></span>
D'>Roy</span><span =
D'><o:p></o:p></span>
style=3D'font-size:10.0pt;font-family:"Tahoma","sans-serif"'>From:</span>=
<span style=3D'font-size:10.0pt;font-family:"Tahoma","sans-serif"'> =
JTClark [via Motion RC Community Forum] =
Sent: =
To: =
roofman
Subject: Re: Freewing Dauntless 1400 =
mm<o:p></o:p></span>
<p class=3DMsoNormal><o:p> </o:p>
<p =
class=3DMsoNormal style=3D'margin-bottom:12.0pt'>I tried everything I =
knew to get the SBD Dauntless flaps to close tighter from TX adjustments =
to servo adjustments with no luck. Finally I figured out a way to get =
both flaps to close tight by securing a magnet on both the top and =
bottom side of each flap with a small amount of Gorilla glue. The =
magnets are small and the exact size of the round holes in the flaps. =
I used one set of magnets on one wing and had to use two on the =
other to get a flush tight finish. The magnets are strong enough =
to keep the flaps closed tight but will release when you deploy flaps =
with your TX switch. This fix also made a big difference in the =
flight performance of the plane by having a completely smooth wing =
surface during flight. <o:p></o:p>
<div class=3DMsoNormal =
align=3Dcenter style=3D'text-align:center'><hr size=3D1 width=3D"100%" =
noshade style=3D'color:#CCCCCC' align=3Dcenter></div><div><div><p =
style=3D'font-size:9.0pt;font-family:"Tahoma","sans-serif";color:#444444'=
>If you reply to this email, your message will be added to the =
discussion below:<o:p></o:p></span>
</div><p =
><a =
href=3D"http://motion-rc-community-forum.1075610.n5.nabble.com/Freewing-D=
auntless-1400-mm-tp1135p1160.html">http://motion-rc-community-forum.10756=
10.n5.nabble.com/Freewing-Dauntless-1400-mm-tp1135p1160.html</a> =
<o:p></o:p></span>
</div><div style=3D'margin-top:4.8pt'><p =
class=3DMsoNormal style=3D'line-height:18.0pt'><span =
style=3D'font-size:8.5pt;font-family:"Tahoma","sans-serif";color:#666666'=
>To unsubscribe from Freewing Dauntless 1400 mm, <a =
href=3D"http://motion-rc-community-forum.1075610.n5.nabble.com/template/N=
amlServlet.jtp?macro=3Dunsubscribe_by_code&nod e=3D1135&code=3Dcm9=
vZm1hbjFAY294Lm5ldHwxMTM1fC03ODI5NTE5MTQ=3D">click here</a>.
<a =
amlServlet.jtp?macro=3Dmacro_viewer&id=3Dinsta nt_html%21nabble%3Aemai=
l.naml&base=3Dnabble.naml.namespaces.BasicName space-nabble.view.web.t=
emplate.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadc=
rumbs=3Dnotify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%=
3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"><span =
style=3D'font-size:7.0pt;font-family:"Times New =
Roman","serif"'>NAML</span></a> =
<o:p></o:p></span>
</div></div></body></html>
There's another circumstance I've encountered before -- didn't think of it while I was replying above. That being, as I had on an AT-6, the foam itself that comprised the flaps was warped from the factory. They were of the 'split' type & no easy way to get 'em off so, I just flew it as was. Kinda halfway planned to replace 'em with self-made balsa flaps but never did.
The flaps bind on the inner part. My friends did the same thing and I had to sand a angle on the inner flap for them to close all the way. End points on the transmitter wont do it. For a more scale effect add 2 more servos so they open and close like the real deal
Its a foam problem, It could of been avoided if a plastic sheet was used but heh. The way I got them to close was: use plastic quick grips and gently close them together. Use a hair dryer, make sure it has a cold setting feature on it. After clamping flaps blow hot air on them being careful not to alligator the surfaces but get them warm then blow the cold air on them. This will get them to close. You may have to to this a few times.
