I echo Ryan and Mike .... first flights today. Unusually gusty spring conditions here but the FRC Spitfire handled the crosswind on landing very nicely!
Official FlightLine RC 1200mm Spitfire Mk.IXc Thread
I've been asked a couple of times where I mounted the RX in my Spitfire. I should have mentioned it in my write up earlier in this thread.
I have the RX stuck to the underside of the canopy magnetic latch just in front of the cockpit. I used a double sided sticky pad. Take the battery hatch off and you can feel a small space just inside the fuselage, it is small but you can fit any normal RX there. The way to do it if anyone is interested. Connect the servo extension leads to the RX, ailerons, flaps, and retracts. Thread them out of the bottom of the fuselage and simply connect them to the relevant servos in the wing. Neatly arrange the excess leads inside the fuselage and fit the wing in place.
This means the RX is out of the way of the battery installation, but you can get to it if you need to. Don't forget to position the short antenna leads so they do not get caught in the battery hatch taking it off and on.
Martin.
I test flew my Spitfire over this last weekend. I've only flown it once so far, and the first flight was on a 4s 2500mah battery. The CG is 73mm from the L/E of the wing measured at the root. I achieved this position with the battery mentioned above placed as far forward as I could get it. The model flies very well on this battery, although I am going to try it on the recommended 4000mah. This will increase the flying time, although this battery may need to be moved back a little to achieve the correct CG.
The first flight was uneventful and I wanted it to be that way. I carried out a full preflight check including a check of all the flying controls at full power before take off. I always carry out a full power check of everything before I take off, this will usually show any signs of problems that may occur during the flight. The only thing I haven't tried so far in flight are the flaps. However loops, rolls, inverted circuits, stall turns are all accomplished using the standard four blade prop and power system. The model presents well in the air and really shows off the classic Spitfire shape.
I am more than happy with the model in every respect and I thoroughly recommend it to anyone who is looking for a new warbird, especially an English one!
Martin
3 more flyers have joined the ranks of those who have flown the pre-production Flightline Spitfire Mk IXc. Time and weather were finally on our side at Skypark.
you can see the photos here:
http://www.rcgroups.com/forums/showt...636353&page=18 post #265.
Sorry, I am having a bit of difficulty with this forum.
Bob
I will have the pre- production Flightline Spitfire at Rancho San Antonio on Saturday. If anyone in the area would like to fly it - come on out. Rancho San Antonio is in Cupertino. I will be there from ~8 am until noon. Then I am off to Moffett Airfield to check out the B-25, B-24, B-17 and the P-51 again!
Bob
