Product page: https://www.motionrc.com/products/pr...nco-1800mm-arf
Surprise, you wanted an OV-10, you've got it! Not only that, but it comes delivered under our brand new and exclusive in house brand for MotionRC Balsa models, 'Nexa'. Nexa the long standing internal desire of MotionRC for a range of balsa models that is reflective of the quality and experience you've come to love from MotionRC and in as much it was very important that we work with partners in balsa that can meet and exceed that level of exception. The result of this, after many man hours is the NEXA OV-10 Bronco. Nexa is a brand for you as can be seen with out first offering, the much requested OV-10 Bronco, so in that vein we look forward and encourage you to let us know what other models you'd like to see in balsa under the Nexa flag...
Getting back to the Bronco, I'm going to post details from the webpage for the Bronco below here along with some pictures and once we get done at Joe Nall, James will follow up with video media on this exquisite model and will add more details in the next few hours in below posts too.
Enjoy and remember, its YOUR brand, and we are listening.
S.
OV-10 Bronco 1800mm (70.8") Wingspan from Nexa - ARF - NXA1000-001
The North American/Rockwell OV-10 Bronco was developed to meet the requirements of the United States Marine Corps Light Armed Reconnaissance Aircraft (LARA) program that was to provide the service with a multi-role aircraft that could operate in the armed reconnaissance and light attack roles from unprepared, forward airstrips. The ability to loiter in the combat area for an extended period was a key requirement.
The Bronco evolved to perform a broad range of roles including observation, forward air control, helicopter escort, armed reconnaissance, utility light air transport and limited ground attack. It has also performed aerial radiological reconnaissance, tactical air observation, artillery and naval gunfire spotting, airborne control of tactical air support operations and front-line, low-level aerial photography.
The Nexa OV-10 Bronco is scaled to approximately 1:6.7 and attention has been given to providing a realistic appearance with outstanding flight characteristics. The model was designed for electric power but can also be flown using a matched pair of internal combustion engines of about 6-7cc displacement.
Features:
S.
Features:
- High level of prefabrication right out of the box
- Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
- Covered in high quality Oracover
- Heavy-duty hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed dummy radial engine, cockpit and interior included
- Fiberglass cowl and control horns with ball link connector
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly.
- Mounts for both electric and gas power options included
- Fully illustrated instruction manual included and also available for download (see tab above)
- Nexa OV-10 Bronco 1800mm (70.8") Wingspan - ARF
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 2x 35 - 42 size Brushless Outrunner Motor - we recommend Admiral GP5 4220-770kV Brushless Motors (Coming Soon)
- 2x 65 - 85 Amp Brushless ESC - we recommend ZTW Mantis 65 Amp Brushless ESC
- 8x 45g standard servos - we recommend HS-485HB
- Electronic 90 degree retracts (81 x 44 x 29mm) - we recommend Xwave RP400-90 Electronic Retract (Coming Soon)
- 6 Cell 22.2V 4000 - 6000 mAh LiPo Battery with EC5 connector - we recommend Admiral 6 Cell 6000 mAh LiPo battery
