Official Discussion Thread: Bancroft 1/200 scale Nimitz Aircraft Carrier - RTR (Ready to Run)
  • Official Discussion Thread: Bancroft 1/200 scale Nimitz Aircraft Carrier - RTR (Ready to Run)
    USS Nimitz CVN-68 1/200 Scale 1700mm (67") USA Aircraft Carrier - RTR
    Click image for larger version  Name:	Nimitz Hero.jpg Views:	1 Size:	182.9 KB ID:	252601
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in high scale RC Warships, Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or sailing on calm lakes or pools, Bancroft vessels are made of high-quality materials including ABS, fiberglass, real wood, and photo-etched brass and steel parts.
    USS Nimitz (CVN-68) is a US Navy supercarrier and one of the most recognizable vessels to ever sail the world's oceans. Originally commissioned as CVAN-68, "aircraft carrier, attack, nuclear powered", then redesignated as CVN-68, "aircraft carrier, multi-mission, nuclear-powered" on 30 June 1975, the USS Nimitz continues her storied service career in 2020.
    Bancroft’s Elite Series of warships presents the 1/200 scale Aircraft Carrier USS Nimitz! Display this museum piece on your mantle or astonish your RC boat club with this functional RTR (Ready to Run) RC aircraft carrier. Over 300 total parts and 100 man-hours of work is already completed for you. Delivered Ready to Run (RTR), the vessel can be sailing within minutes of arrival, using the included 2.4Ghz radio transmitter, 2s Li-Ion battery, and charger. Only four AA batteries, ballast and minimal assembly is required. Set sail in minutes!
    Pin-Sharp Details
    Over 100 hours of handcrafted details are completed at the factory using hundreds of fingernail sized brass Photo-Etched (PE) parts and larger molded sub-assemblies.
    The spacious hull and superstructure are ideal bases for additional customization, weathering, and LED lighting.
    Active Flight Deck
    Position numerous included aircraft around the flight deck, including 1/200 scale F-18 Hornets, A-6 Intruders, E-2 Hawkeyes, S-3 Vikings, and SH-3 Sea King helicopers. Each aircraft arrives painted in base gray with basic insignia, and can be customized to represent your preferred squadrons during the Nimitz's many tours of duty.
    Exceptional Scale Realism
    Weighing nearly 30 pounds and stretching over 5.5 feet long, the Bancroft 1/200 scale Nimitz becomes the instant centerpiece of any military RTR RC maritime collection.
    Transport is not *that* difficult, but it will need to be lengthwise in a four door vehicle. In a sedan, you'll need to fold down the rear seat, and also ensure you have the following cavity available to fit the complete model:
    1700mm length
    425mm beam (width)
    365mm height
    Loaded with Accessories
    The Nimitz includes over one dozen 1/200 scale vehicles and equipment to support flight operations.
    I don't think 1/200 RC is possible, but I'm certain an intrepid modeler could configure a magnetized sub-floor mounted track under the hull, that could simulate moving vehicles by pulling the topside vehicle around.
    Four Motor Drive System
    Four pre-installed motor drive systems with steel drive shafts and three-bladed propellers propel the Bancroft Nimitz. All drive shafts and both rudders are waterproofed for your convenience.
    Without bow thrusters, the 1/200 Nimitz prefers to be turned while underway. Or a 1/200 tugboat fleet...
    1/200 Scale Battle Group!
    Sail the Bancroft 1/200 scale Nimitz aircraft carrier alongside similarly scaled vessels including the Bancroft 1/200 scale Missouri battleship.
    FEATURES:
    • RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
    • 2.4Ghz radio system and all electronics Pre-Installed
    • Fully Painted and Detailed
    • Zero assembly required --Get underway in minutes!
    • Durable fiberglass one-piece molded hull and deck
    • Hundreds of brass photo-etched (PE) parts and high detail parts
    • Extensively detailed and hand finished
    • Hyperscale detail comprising over 100 hours of hand craftsmanship
    • Four motors with steel drive shafts and counter-rotating propeller pairs
    • Quick-Detach Superstructure for easy access to the ship's interior
    • Pre-Installed Rigging with simple disconnect design
    • Rated for calm ponds, pools, and lakes appropriate for RC Boats
    INCLUDES:
    • Bancroft USS Nimitz 1/200 Scale 1700mm (67") USA Aircraft Carrier - RTR
    • 2.4Ghz Radio and Receiver, pre-installed
    • Four motor drive system, pre-installed, with XT60 battery connector
    • Steering servo, pre-installed
    • 2s 7.4V 2800mAh Battery with XT60 connector
    • 2s Battery Charger
    • Basic Tabletop Display Stand
    REQUIRES:
    • Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH
    Reserved for photos and video
      Impressive, very nice model.
      Please do in-depth thread on Missouri 1/150 scale.
        Wow 🤩 this is absolutely amazing!!! I’m about to go broke
          Don't know what to say, this one is really amazing, I'm totaly blown away...
            Now THAT is serious business right there. Absolutely stunning!
              We broke ground on the swimming pool my wife has always wanted last week.
              She still hasn't figured out why one end slopes like a boat ramp and another area looks an awful lot like a shipping port.
              She’ll understand once My “Fleet” starts sailing.
              Best regards,
              Cris B.
              AMA#L945841, NASA#2845, JPO#2503,
              NSRCA#4603, IMAC#7357
                Alpha do you know what's the diameter of prop shafts and stuffing tubes on this model (and the rest)?
                This model and Missouri 1/150 scale side-by-side have to be an impressive sight....can't wait for October to be here.
                  looks like a 90's air wing without the f-14's...are aircraft plastic or metal?
                    MAVFLIGHT75 The aircraft are molded plastic, with occasional metal parts and resin parts.
                    • #11
                      Thanks Alpha for response on aircraft.
                      How do you access interior...any pics available?
                      It doesn't look like it has an interior hangar bay based on the elevator sliding doors being closed ...just thinking ahead what is needed to get a full hanger bay in based on size of interior access area
                      The exterior looks great
                      • #12
                        MAVFLIGHT75 Hi Mav, there is a large hatch concealed on the main deck. This hatch gives access to the internal battery placement, electronics, and motors. There is plenty of space for an intrepid modeler to fabricate a full hangar bay and operable elevators, since they are positioned along the perimeter of the deck.
                        I look forward to your project!
                        • #13
                          yep...working elevators, lights, full hangar bay, & working blast deflectors
                          just purchased my 1st batch of modern wing 1:200 aircraft
                          • #14
                            MAVFLIGHT75 I like the way you think. Welcome to "The Squawk". Looking forward to pictures and comments when you receive this beast. Best, LB
                            • #15
                              just noticed... Is that a real weight 30Lb's what is she ballasted with? Bricks?😁 Probably a fat finger right.
                              • #16
                                She's a big and heavy boat, once fully fitted. 28.9lbs on the scale, according to my notes. There was some ballast in the model I sailed, but it wasn't anything out of the ordinary for a boat this size. The nice thing about a hull that cavernous is that with most of that weight converted to battery, the boat can run all afternoon.
                                • #17
                                  I like Alpha will be watching your project unfold. My interest is because I'm a Nimitz plank owner.
                                  My squadron VA-35(A-6) was attached to the Chester W when commissioned 3 May 75 as we were part of its sea-trials off of Gitmo earlier in March.
                                  • #18
                                    This is really awesome. I have always wanted a big carrier. Any chance they will make a bigger one?
                                    MAVFLIGHT75. What planes did you get? Looking forward to your build!
                                    • #19
                                      I’ll buy the aircraft carrier rc maybe in tax time
                                      • #20
                                        Anyone have any updates of when we can place an order? Said late DEC.....well its let DEC !!!!!
