Official Bancroft Dusseldorf 1/25 Scale Fireboat Discussion Thread
  • Official Bancroft Dusseldorf 1/25 Scale Fireboat Discussion Thread
    The Düsseldorf Firefighting Boat, known as the "Feuerlöschboot Düsseldorf," is a crucial asset in the German city's emergency response infrastructure, particularly for incidents on the Rhine River and within the bustling harbor area. This specialized vessel is equipped with advanced firefighting and rescue equipment, enabling it to tackle fires, hazardous material spills, and rescue operations with efficiency and precision.
    Designed to deliver high volumes of water or foam through powerful water cannons, the boat can effectively combat large-scale fires on ships, waterfront buildings, and industrial facilities. Its high-capacity pumps (over 20,000 gallons per minute) provide a powerful water stream drawn directly from the river or onboard reservoirs, allowing sustained firefighting efforts even in challenging conditions.
    The Feuerlöschboot Düsseldorf also plays a pivotal role in rescue missions, providing a stable and accessible platform for evacuating individuals from hazardous situations. Advanced navigation systems and communication equipment enable seamless coordination with other emergency services, ensuring a comprehensive and integrated response.
    Over the years, the boat has undergone various upgrades to incorporate the latest technologies, enhancing its firefighting and rescue capabilities. This modernization ensures that the vessel remains a state-of-the-art tool in protecting Düsseldorf's residents, infrastructure, and environment from waterborne emergencies.
    Bancroft’s 1/25 scale Dusseldorf allows an impressive museum-quality piece to be displayed on your mantle or astonish lakeside spectators with this functional RTR historic model. Hundreds of parts are already assembled, painted, and installed for you. Delivered Ready to Run (RTR), the vessel can be sailing within minutes of arrival, using the included 2.4Ghz radio transmitter, 7.4v 2S LiPo battery, and charger. Only four AA batteries and minimal assembly is required. The water cannons are plumbed and ready for the addition of an additional brushed ESC (such as ADM6003-002) to control the cannons from the transmitter!
    Ready To Run
    A 2.4Ghz radio system is included and factory installed, as are all internal electronics. A LiPo battery and charger are also included. Simply charge the included primary battery with the included charger, insert your AA batteries into the radio transmitter and leave port!
    Supremely Detailed
    The scale fidelity evident on the Dusseldorf includes hand-applied details including rails, grabs, lights, life buoys, ladders, and genuine wood decking.
    Operating Water Cannons
    The water cannons, pump, and plumbing are all factory installed. Simply add an additional brushed ESC (available separately) to make the cannons operational from the transmitter.
    Powerful Propulsion
    The twin screw drive system with four rudders provides exceptional maneuverability when fighting fires or performing rescue missions.
    Features:
    • RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
    • 2.4Ghz radio system and all electronics installed
    • Fully painted and detailed
    • Zero assembly required — get underway in minutes
    • Durable fiberglass one-piece molded hull
    • Hundreds of high detail parts
    • Extensively detailed and hand finished
    • Incredible scale detail representing more than 180 hours of hand craftsmanship
    • Dual motors with steel drive shafts
    • Removable superstructure for easy access to the ship's interior
    • Factory-installed rigging with simple disconnect design
    • Rated for calm ponds and lakes appropriate for RC boats
    Includes:
    • Bancroft Dusseldorf 1/25 Scale 1172mm (45.7") Fireboat - RTR
    • 2.4Ghz radio and receiver, factory-installed
    • Twin motor drive system
    • Two screws (propellers)
    • Waterproofed hull and drive shafts
    • Steering servo, installed and adjusted
    • 2S 7.4V 2800mAh battery with XT60 connector
    • 2S battery charger
    • Basic tabletop display stand
    Requires:Important Information - Please Read
    Bancroft model boats are molded and hand finished using very intricate details and parts including metal, wood, plastic, and fiberglass. Because of their hand made nature, minor imperfections in the fiberglass, metalwork, or painting may exist. These potential imperfections will not affect the seaworthiness of the vessel or the overall scale boating experience. Bancroft scale RC boats are fragile so care should be taken when moving or transporting your model.
    Some of the electronics in this Bancroft boat, including the Battery, ESC, Motor, and Receiver, are NOT intended to get wet; they are NOT water resistant. If any of these electronic components get wet and you attempt to operate your model, the water can cause an electrical short-circuit and void your warranty. In the rare instance that you get water inside your vessel, you should drain the water completely and allow all electronics to fully dry before attempting to operate your model. Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 1 Hour
    Scale 1/25
    Length 1172mm / 45.7in
    Width 252mm / 9.8in
    Height 360mm / 14.0in
    Hull Material Fiberglass
    Battery 7.4V 2800mAh LiPo
    Battery Quantity 1
    Battery Connector XT60
    Motor
    • 2x 550 brushed motors
    • 380 brushed motor for water cannons
    Motor Quantity 3
    Propeller Material Metal
    Contra-Rotating Propeller Yes
    ESC 80A
    ESC Waterproof Splash-Proof
    ESC Quantity 1
    Radio Stick
    Receiver Channels 6
    I am interested in buying this model. The detail says they the water cannons need a separate ESC for them to work with the receiver/transmitter it comes with. Can someone point me to the ESC I need to order?
      nd ESC from Bancroft or buy another in an ordinary RC-shop. You don´t need something special..............Good luck!
