Oxidean Marine Animal Cat 38" Twin Electric Build
  • Oxidean Marine Animal Cat 38" Twin Electric Build
    Animal #2 is on the work bench. The hull/hardware combo is perfect for the hobbiest building their own setup and comes with every nut/bolt/cooling line needed to complete it. I was extremely impressed with how the Animal Cat performed so I decided to stick with what I know and continue pushing forward. Big thanks to Bill for hooking up the boat and slightly used ESCs/servo at a price I couldn't refuse and offering warranty. Shout out to Off Shore Electric's for always delivering the power I need! Here's the build list:
    *Oxidean Marine Animal Cat hull/hardware
    *Oxidean Marine T180 ESC's
    *Leopard 4082 2000KV motor's
    *Turnigy power
    *Chris Hoffman X447 props
    *Futaba T6EX
    *ProAmps BLS108 servo
    *Pool-noodles galore!
    Was wondering when you buy a hull with hardware do all the holes come pre drilled on the transom?
      Sorry for the late reply. In this case, yes all holes are drilled. Other boat project hulls you have to measure and drill out all your holes for mounting the hardware. The hull/hardware combo from Oxidean Marine saves you that time and comes with solid hardware.
