Official Bancroft 225mm Magic Vee V5 Micro Racing Boat RTR Thread
  • Official Bancroft 225mm Magic Vee V5 Micro Racing Boat RTR Thread
    Magic Vee V5 Micro 225mm (8.9") Racing Boat from Bancroft - RTR - BNC1028-001
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    Easy to drive, the Bancroft Magic Vee delivers the speed, control, and style needed to rule the pool or pond in a convenient Ready To Run (RTR) package. Open the box, charge the included battery with the included charger, insert your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for balanced speed and maneuverability out of the box without any additional adjustment. The Bancroft Magic Vee sports a slick racing scheme, accented by race-inspired decals.
    Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Magic Vee can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 2S battery, and battery charger. Only four AA batteries are required to begin racing!
    High Performance Equipment
    Impressive acceleration and sustainable high speeds are delivered by a water-cooled marine 180 motor and reliable micro marine ESC. The included 2S 320mAh LiFePO4 battery and convenient USB charger deliver high performance and extended run times!
    CAD-Designed Hull
    The Magic Vee’s ABS plastic hull is digitally-optimized to deliver outstanding performance and razor-sharp handling in compact areas like pools and small ponds. A convenient boat stand is also included for when the Magic Vee is in dry dock!
    Durable Running Hardware
    Including features usually found only on larger and more costly boats, the Micro Vee has a flex-shaft prop drive and adjustable turn fin that allows you to dial-in the boat for any operating environment or water condition.
    Micro-Size, Macro-Performance
    Don’t let the compact size and economical price fool you, the Magic Vee is fast, agile, and enormously fun to drive! Grab a pair and race your buddies in most any swimming pool or small pond.
    2.4GHz Pistol Grip Transmitter
    A reliable, interference-free radio system ensures that the Magic Vee is always under your control at distances of up to 100M (300’).
    Easy To Transport
    Take the Magic Vee V5 Micro anywhere with big power in a small package.
    • All Electronics are pre-installed
    • Fully Painted and Detailed
    • 2.4Ghz radio system and all electronics Pre-Installed
    • Extensively detailed and hand finished
    • Rated for calm ponds, pools, and lakes appropriate for RC Boats
    • Bancroft Magic Vee V5 Micro 225mm (8.9") Racing Boat - RTR
    • 2.4Ghz Radio and Receiver, pre-installed
    • Brushed water-cooled motor drive system, pre-installed, with JST battery connector
    • 2S 6.4V 320mAh Battery
    • 2S Battery Charger
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :15 minutes
    Scale N/A
    Length 225mm / 8.9in
    Width 70mm / 2.8in
    Height 70mm / 2.8in
    Hull Material ABS
    Battery 2S 6.4v 320mAh LiFePO4
    Battery Quantity 1
    Battery Connector JST
    Motor 180 brushed, water-cooled
    Motor Quantity 1
    Propeller Material Nylon Composite
    Contra-Rotating Propeller No
    ESC 5A
    ESC Waterproof Splash-Proof
    ESC Quantity 1
    Radio Wheel
    Receiver Channels 2
