nice to meet you.
traxxas x-maxx 8s jump and drive at high speed
The new servo made in China is dead.
So I made a big decision and proceeded to replace the large servo.
Ha... it was too hard work. ㅜㅜ
I worked on it after 3 days and it was my first time, so I referenced several YouTube videos.
However, there was no easy way.
How to make the parts to fix the servo separately, or how to coat it with a glue gun....
I squeezed my head and worked in a way that was easy to replace later and had good fixation.
Of course, you have to do a test drive to see if it's okay.
First, this is a video of a large servo operation.
-POWER HD WH 65KG Digital Servo Metal Gear-
Torque(6.0V): 55.0 kg-cm / ( 763.8 oz/in)
Torque(7.4V): 60.0 kg-cm / ( 833.2 oz/in)
Torque(8.4V): 65.0 kg-cm / ( 902.7 oz/in)
Speed: 0.19 sec (6.0V)│0.17sec (7.4V)│0.15 sec (8.4V)
Operating Voltage:6.0 ~ 8.4 DC Volts
Weight: 200.0 g (7.05 oz)
Bearing Type:Ball Bearing x 2
Motor Type:DC Motor
Gear Type:Copper & Steel
Operating Temperature:-20℃~60℃
Working frequence:1520μs / 333hz
Size:65.8x30.0x55.6mm (2.59x1.18x2.19 inch)
Motor Type:DC Motor
