Vortex Pro High Speed 1/18 Scale 4WD Buggy (Green) - RTR from XK Innovations -WLT-A959-B-GREEN
Version Info: The Pro version Includes a 2S 7.4V 1500mAh LiPo battery with larger 540 motor capable of speeds up to 30mph. Additionally the Pro version includes a larger ESC, tweaked suspension with higher spring rate, different drive shaft and gearing.
The XK Innovations Vortex Pro High Speed Buggy is a 1/18 scale buggy that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
Adjustable Suspension Fully independent front and rear suspension work to absorb punishment while keeping your wheels on the ground as much as possible. Adjust the suspension at various points to tune its performance to your preference! |
| Easy To Maintain Thrilling performance is matched with an aggressive buggy racer configuration and iconic body style. The shell is quickly removable to access internal electronics |
Four Wheel Drive Accelerate with maximum traction using active four wheel drive! |
| Durable Design The tough body materials can absorb a lot of punishment. |
Upgradeable Perfect out of the box for most drivers, this buggy is also easy to tinker with, upgrade, or customize for creative gearheads looking for an affordable base vehicle. |
| Ready To Run (RTR) Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v LiPo battery, and convenient battery charger are included. |
- Functions: forward, backward, turn left, turn right, direction trimming
- Big wheels and high chassis provide good climbing performance
- Has no problem going through the dirt, grass, and gravel
- 2.4GHz technology with four-wheel-drive system to provide plenty of power
- 4 wheel drive to ensure a stable and smooth driving experience
- XK Innovations Vortex Pro High Speed 1/18 Scale 4WD Buggy (Green) - RTR
- 2.4GHz Transmitter and charger
- 2s 7.4V 1500mAh LiPo battery with T-connector
- Four (4) AA size batteries for the radio transmitter
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : NONE
| Model Scale | 1/18 |
| Length | 245mm / 9.6in |
| Width | 175mm / 6.8in |
| Height | 94mm / 3.7in |
| Weight (No Battery) | 1700g / 59.96oz |
| Wheelbase | 165mm |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | N/A |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | 61mmx28mm |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | Oil-Filled |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | Brushed 540 Motor |
| Battery | 7.4V 1500mAh LiPo battery with T-connector |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 17g |
| Radio | N/A |
| Lights | No |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Intermediate |
| Assembly Time | 1+ Hours |
| Recommended Environment | Offroad |
