Mad Crusher VE EP-MT Readyset 1/8 Scale 4WD Truck - RTR from Kyosho - KYO34254B
Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter and 1 or 2 (7.2V Ni-MH or 7.4V Li-Po up to 14.8V max) for the chassis, purchased separately (see Requires below for details).
Let the might and power of this monster machine inspire you with its dominant presence and performance over the toughest terrain. Get your adrenalin pumping by ripping around wide-open spaces at full throttle as you wreak true R/C truck mayhem! Based on the heavy-duty Mad Force Cruiser chassis, the new Mad Crusher VE incorporates a newly developed 5-link suspension system featuring ball joint upper and lower links in combination with lateral rods that deliver a deeper, supple stroke, more characteristic of rock crawlers.
Equipped with the powerful 2000KV Kyosho Speed House Torx 8 brushless motor, you can drive over any surface from tarmac to off-road in 70's American pick-up truck style with realistic scale wheels and tires. Simply add AA-size batteries for the transmitter and a battery for the chassis and the Mad Crusher VE Readyset will get you straight into monster trucking action and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
5-Link Suspension
Supple movement characteristics of the new 5-link suspension supports the dynamic performance of this 4,000g + heavyweight machine.
Superior Surface Tracking and Stability
Lateral rods equipped on front and rear control the movement of the suspension to ensure superior surface tracking and stability.
Scale Appeal
Chrome plated injection molded grill, bumper, wipers and mirrors are included to create a breathtaking level of detail. Optional Light Unit (97054-2) can also be installed in the included light buckets.
Sure-Footed Performance
Massive 150mm x 70mm block-pattern tires and black wheels deliver sure-footed performance in formidable style.
Speed House BRAINZ 8 ESC
Equipped with the new Kyosho Speed House BRAINZ 8 ESC incorporating electronic fan. Features brake, reverse, auto-cut voltage, impact protection program settings.
Beyond Adequate Power
Featuring the new Kyosho Speed House TORX 8 (waterproof) Brushless Motor 2000KV that can effortlessly power this heavyweight machine through rough terrain with excellent acceleration.
Twin Batteries Possible
Batteries are mounted in separate boxes on each side of chassis for superior balance. 7.2V Ni-MH to 7.4V Li-Po twin pack batteries can be mounted.
Syncro KT-231P+ 2.4ghz Transmitter
Set throttle trim, steering trim, throttle EPA and steering dual rate simply by turning dials on the included Syncro KT-231P+ 2.4ghz transmitter.
FEATURES:
  • Fully assembled Readyset only requires four AA-size alkaline batteries for the transmitter and battery for the chassis
  • 1/8 scale Mad Force Kruiser 2.0 VE monster truck chassis base incorporates new 5-link suspension
  • Pre-cut and painted scale body complete with decals applied recreates the 70's American truck style
  • Rigid axles on front and rear with solid casing effectively transfer power into traction
  • Diff gears incorporate steel spiral gears on front and rear to handle high power loads
  • Kyosho Speed House brushless system provides powerful performance
  • Includes Syncro KT-231P+ transmitter and Syncro KR-331 receiver with failsafe function
  • Receiver and battery are stored in radio box for protection against shocks and dirt
  • Waterproof high-torque KS5031-09MW steering servo incorporates metal gears for reliable control of the big chassis
INCLUDES:
  • Kyosho Mad Crusher VE EP-MT Readyset 1/8 Scale 4WD Truck - RTR
  • Factory assembled chassis
  • Pre-cut and painted body complete with decals applied
  • 2.4GHz Syncro KT-231P+ transmitter
  • Conversion connector x1 (for battery)
  • Hex wrenches (1.5mm, 2.0mm, 2.5mm, 3.0mm)
  • Cross wrench (large)
  • 17mm wheel wrench
REQUIRES:PRODUCT SPECIFICATIONS:
AGE LEVEL : 11 AND UP
SKILL LEVEL : BEGINNER
BUILD TIME : NONE
Model Scale 1/8
Length 590mm / 23.2in
Width 376mm / 14.8in
Height 275mm / 10.8in
Weight (No Battery) 4700g / 165.7oz
Wheelbase 351mm / 13.8in
Ground Clearance N/A
Body ABS Plastic
Chassis 4WD
Drivetrain N/A
Wheel Size (Diameter x Width) 150mm x 70mm
Wheel Hex Size N/A
Tire Tread 306mm
Bushing Material N/A
Suspension N/A
Shock Type N/A
Transmission N/A
Gear Pitch N/A
Internal Gear Ratio 20.52:1
Final Drive Ratio N/A
Pinion N/A
Spur Gear N/A
Differential N/A
Ball Bearings N/A
Brakes N/A
Electronic Speed Control N/A
Motor Speed House TORX 8 (waterproof) Brushless Motor 2000kV
Battery 4x AA and 1 or 2 (7.2V Ni-MH or 7.4V Li-Po up to 14.8V max) (required)
Servos N/A
Radio Syncro KT-231P+ transmitter
Lights No
Sound No
Water Resistant N/A
Skill Level Beginner
Assembly Time None
Recommended Environment Outdoors, smooth to rugged surfaces
