MAN TGX 26.540 6X4 XLX 1/14 Scale Semi Truck - KIT from Tamiya - TAM56346
Version Info: This truck is a KIT. Assembly is required. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya MAN TGX 26.540 6x4 XLX resembles the classic conventional tractor truck. Powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The MAN TGX 26.540 6x4 XLX's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
540-Sized Motor and 3-Speed Transmission The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles. |
Exceptional Scale Detail Scale details surround this truck for exceptional realism. |
Dual Rear Axles Each axle is supported with leaf spring and shocks. |
LED Light Buckets You can install your own LED lights (sold separately) to further the scale appeal. |
1/14 Scale This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport. |
Add Your Own Electronics and Drive! Once you add your preferred electronics you're ready for those on-road adventures. |
- Exceptional scale detail and realism brings this truck to life on every level
- The realistic interior includes seats and dashboard while metal-plated parts as well as metal transfer emblems enhance exterior detail
- The included coupler enables connection with any currently available Tamiya 1/14 scale trailer
- Cabin tilts forward just like the actual truck
- Metal leaf springs and friction dampers enable realistic suspension movement
- When controlled with a separately available R/C system, the 3-speed transmission enables authentic gear changes while driving
- The model features a realistic body and a 3-axle chassis with durable ladder frame
- Cab, F, H, K, M and CC parts are replaced with pre-painted Gun Metal color parts
- Tamiya MAN TGX 26.540 6X4 XLX 1/14 Scale Semi Truck - KIT
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 6 Cell 7.2V NiMH Brushed ESC
- Standard size servo - we recommend the Hitec HS-311 Plastic Gear Standard Servo
- 6 Cell 7.2V 1600mAh NiMH battery with universal connector
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
Model Scale | 1/14 |
Length | 458mm / 18.0in |
Width | 193mm / 7.5in |
Height | 298mm / 11.7in |
Weight (No Battery) | N/A |
Wheelbase | 272mm / 10.7in |
Ground Clearance | N/A |
Body | ABS Plastic |
Chassis | Aluminum |
Drivetrain | 3-Speed |
Wheel Size (Diameter x Width) | N/A |
Wheel Hex Size | N/A |
Tire Tread | N/A |
Bushing Material | Metal and Plastic |
Suspension | Leaf Spring |
Shock Type | Friction Damper |
Transmission | 3-Speed |
Gear Pitch | N/A |
Internal Gear Ratio | N/A |
Final Drive Ratio | 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1 |
Pinion | N/A |
Spur Gear | N/A |
Differential | Gear |
Ball Bearings | N/A |
Brakes | Electronic |
Electronic Speed Control | 6 Cell 7.2V NiMH Brushed ESC (required) |
Motor | 540-Brushed |
Battery | 7.2V 1600mAh (required) |
Max Battery Dimensions (L x W x H) | N/A |
Servos | 1x standard size (required) |
Radio | 4+ Channel (required) |
Lights | No |
Sound | No |
Water Resistant | N/A |
Skill Level | Intermediate |
Assembly Time | 3+ Hours |
Recommended Environment | On-road, smooth, paved surfaces |
