Official Fly Wing 450L V2 450 Size Helicopter Discussion Thread
  • #21
    I had a crash when I went from inverted to upright. The belt slipped and it crashed to the ground with no power. The belt is very loose, I had this happen before. The belt drive mechanism needs to be improved.
    • #22
      I replaced the feathering shaft in my 450. I didn't find a thrust bearing. Does it have thrust bearings?
      • #23
        I have seen these advertised as V2 450 and V2 450L. Is there a difference? What does the "L" stand for?
        • #24
          Where can I get information on if/how to fit a scale body to my FW450. I looked at YouTube videos for this 'copter but didn't see anything of that nature.
          • #25
            Originally posted by xviper View Post
            Have you tried the "return home" yet? I'm wondering if it knows where "home" is without the compass calibration. I take it that it does the "position hold" well?
            If the compass wasn't calibrated it wouldn't hold position and would likely start circling and crash. I know because my Hubsan Zino drone compass lost it's calibration and the drone circled out of control and flew away into the next neighborhood where it was destroyed when it hit a tree and fell into someone's back yard.
            • #26
              Nice! I guess the calibration procedure is for "just in case". I use the Bigaole Return to Home module in all my sailplanes and never have I had to do any GPS calibration on them. They just secure the satellites and simply works.
              Magnetic north varies slightly by location, depending on where the 'copter compass was calibrated before you got it will determine how accurately it will hold it's position and/or RTH. Ideally if you are flying x number of miles away from the location where the compass was previously calibrated you should re-calibrate the compass. The value of 'x' may be unknown by you or you may not be able to accurately ascertain if it's compatible with your location so ROT when in doubt always calibrate a new drone/heli/compass to your home location before attempting to fly with the GPS turned on.
              • #27
                Thanks for the info, however, it's been a while now and Motion (or any other trust worthy sellers) never got any stock since I was first interested in this. I don't trust the sellers that has these in the Asian markets. Now, with some of the "iffy" reports, I've moved on and this is off the table.
