500 size UH-1C Huey - 174th AHC
After a full day of work, the mechanics have been set up, programmed, hovered, and installed in the airframe. Also installed the tail position lights and flashing beacon. Still have solve a few issues, but maiden flight should be soon! Then I will be working on getting the paint work finished up, and doors/windshields mounted.2 Photos
Originally posted by Prowler901 View PostAnother fine bit of workmanship there, Delta. She's lookin' good! :Cool:
Originally posted by JFandL View PostYes the lights are very bright, going to look good in the air. I've started on my 500 T-Rex mechanics for the build for a new UH-1B. Should be ready to test fly the mechanics by next week. Then all the real fun stuff starts again . ROFL
John
Made some more progress on the Huey today. Installed the roof antennas and pitot probe, completed rivet work in a few missing spots (mostly the entire underside). After some primer to seal over the rivets, I couldn't resist shooting some OD on, and painting the glade shield on the nose. Still have to work on a few more airframe details before continuing paint, but its starting to get there. I need to install the "towel rack" VHF antennas on the tail, add the tail stinger, and am considering a rework on the H-stabs. The manufacturer appears to have put B model sized stabs on, and they aren't perfectly aligned. The C had a much larger chord than the B, so I might try extending them with balsa and FG. Also looking at adding the cargo hook on the bottom, it's too prominent of a feature for me to omit from the airframe.4 Photos
John
Haven’t had much time to work on this, but I’ve started on the basics. Glued in a 1/4” plywood base over the gear mounts, with will serve as the mounting point for the mechanics. Also finished installing all the servos and electronics within the mechanics. Tonight, I installed a Freewing light controller and some of the LEDs from the 90mm F-16, and they are super bright! Still have to install white lights on either side of the tailcone, and the beacon above the engine.1 Photo
Originally posted by JFandL View Postcould you post a picture of the Roban tail box?? Would love to see if its now like the old heliartist type1 Photo
Originally posted by JFandL View PostDid you do the scale rivets? or did it come that way?
Specs so far:
Motor: Savox BSM3750 1200KV
ESC: Castle Edge 100A
Battery: 6S 4000mah
Cyclic servos: DS515M
Tail Servo: DS8910A+
FBL: iKon2 FBL
Thanks guys, it going to be fun project!
Originally posted by Akubudaklaut View PostHi there..can I know where u get that scale body?
