Roban Apache 700 size build
  • Roban Apache 700 size build
    Starting to put together the Apache 700, lots of parts to this big boy.
    Upgraded main gear set from Quick UK very good quality
      Mechanics are coming together
        Motor installed and belt tension set correctly, belt tracking centered on the drive gear. very Important !!
          Wiring all coming together, solderd on bullet connectors and EC5 plugs really sucks ! Went to do a voltage test on my leads coming off for the UBEC's and fried one JST plug ... nobody is perfect !
            I plan to fly and tune the mechanics/gyro on a test board before installing into the body.
              The factory finish from Roban leaves a lot to be desired. Cheap easy fix ? Yes ! camo green spray paint from Wal-Mart is a close match and looks great for a base color. Plan to weather this baby up real good !! I added a small chrome strip to the inside of the windows for a start on detailing and it looks close to the real thing.
                Wow, that looks like a fun build! I will be following this as hopefully some day the finances will allow me to get one. Is the Huey in the background a Roban as well? That's what I plan to build in the future.
                  Yes that is the 600 size Huey back there, flies very well I just need to finish up details on the outside and the interior but I will start another thread for that one.
                    So far this will be my basic layout for the batteries and ESC, looks like it will work out pretty well. I have been told the interior can run hot so I have punched some holes into the sides and intend to add some cooling fans to combat this. The holes alone will allow more air to circulate around the batteries.
                    • #11
                      So here is my cooling system for the interior to keep the temps down on all the electronics, Cut open the sides to access the engine or turbine area for the heat to exit out of. Found some small 5volt computer fans and used garage door foam seal to create a nice pressure fit and they will blow the hot air right out the back through the exhaust.
                      • #12
                        Bench test of the mechanics https://www.youtube.com/watch?v=WlwH9_cN3SQ
                        • #13
                          Day Bright lighting system GT 3W kit https://www.youtube.com/watch?v=84REN_CixW4
                          • #14
                            Nice work so far! Really looking forward to the build! Just picked up the 700 Cobra myself for a winter build.
                            • #15
                              Weekend progress.
                              • #16
                                Ordered some lens covers for the strobe lights will see how they work out.
                                • #17
                                  getting closer to a test flight ! gyro is programmed and everything checks out so far.
                                  • #18
                                    Started getting the body together today. Had to do some shaping to get the tail to fit just perfect but so far so good and it is nice to see it sitting on the landing gear !
                                    • #19
                                      Had these pilots made for my 600 size Huey but dang ! I think I can make them for for the Apache as well. They are from http://realmodelpilots.co.uk/
                                      • #20
                                        So how's the build going?
