Need help building a quadcopter with a 14" prop blades
  • Need help building a quadcopter with a 14" prop blades
    Hi everyone;
    i need help in building a quadcopter with 14" blade propellers and don't know whitch or what kind of electric motor i need?
    Also what ESC-BEC.
    Any help will be greatly apreciated, thanks.
    Look at "3D" aerobatic models that use 14 inch props if all you want is relatively slow movement but heavy lift for the power used.
    Look at higher speed models if you want a faster quad.
    You'll probably be going to standard ESCs and separate BEC or battery for the RX This depends on what (if any) other loads will be on the RX's power "buss" The stabilizer and ESCs won't draw a lot
    In essence: You have to say more about what you want to do.
      Thanks For the fast reply,...
      i will look into the info you sent and will be more specific on what my proyect is more intended.
