New to the forum with a UH1-D 800 series
  • #61
    Ahhh okay...
    Yes I flipped my tail over as well.
    • #62
      Small changes of the week:
      Manufacture of a support for the controller's fan with a 3D printer.
      Click image for larger version  Name:	IMG_5890_01.JPG Views:	0 Size:	85.8 KB ID:	346672
      Securing the 2 torque tube, the tips being just glued, I drilled and screwed them.
      Click image for larger version  Name:	IMG_5894_01.JPG Views:	0 Size:	319.9 KB ID:	346673
      • #63
        Hi,
        This week:
        Modification of the fuselage of the UH-1D
        Replacement of the upper glazing (completely false) Vario 250/33, fiberglass, epoxy resin and polyester putty to plug the holes.
        Cliquez sur l'image pour la voir en taille réelle   Nom : 		IMG_5902_01.JPG  Affichages :	0  Taille :		98,4 Ko  ID : 			347247
        Modification of the landing gear (step, tips). Addition of ventilation intakes and upper position lights.
        Cliquez sur l'image pour la voir en taille réelle   Nom : 		IMG_5899_01.JPG  Affichages :	0  Taille :		144,9 Ko  ID : 			347248
        Replacement of the upper Beacon.
        Cliquez sur l'image pour la voir en taille réelle   Nom : 		IMG_5901_01.JPG  Affichages :	0  Taille :		133,6 Ko  ID : 			347249
        Relocation of the rear navigation lights.
        Cliquez sur l'image pour la voir en taille réelle   Nom : 		IMG_5900_01.JPG  Affichages :	0  Taille :		142,6 Ko  ID : 			347250
        To be continued.....
        • #64
          First coats of paint RAL 6003 Mat
          The paint is not yet dry (that's why it shines)
          Feel free to correct me if you don't understand my English, I wouldn't be offended
          • #65
            Hi,
            Installation of accessories: antennas, air intake, cable cutters, hinges, etc...
            2nd coat of paint.
            We can see on the rocket launcher pods the difference in color: On the left the RAL 6003, on the right the green Roban...
            • #66
              Looks great!
              You are pretty much doing the same thing I'm doing! I am making all the same changes... I like that fan mount! Do you mind sharing the 3D file?
              I'm not going to mount the rocket pods... as I'm going with a 'slick' version...
              • #67
                Hi sfcfury,
                I'm not going to mount the rocket pods too, i'm waiting for choosing.
                I send you the stl file by email.
                • #68
                  Installation of upper glazing, drilling and installation of rivets.
                  Masking of glazing before painting.
Name:	IMG_5910 - copie.jpg
                  • #69
                    The painting is almost finished, (except the windshield which is very ugly and that I will redo) before the last finishes I mounted the mechanics to make a test flight.
                    I also replaced the Roban light module with an Aurora Optotronix module that allows more functions.
                    https://www.hacker-motor-shop.com/Lighting/Optotronix/Optotronix-Aurora-LCU-EVO2.htm?shop=hacker_e&SessionId=&a=article&ProdNr =OPT2000&p=10169
                    • #70
                      Looks fantastic man! I'm using the unilight control module myself...
                      • #71
                        Unilight here also......
                        • #72
                          OK, your Unilight module has almost the same functions as my Aurora
                          • #73
                            Some photos of the Huey progress.
                            Painting of the rotor head in grey.
                            Painting the tail blades.
                            Installation of some decals, but their quality is so bad that I will make redo others.
                            Click image for larger version  Name:	IMG_5924_01.JPG Views:	0 Size:	158.2 KB ID:	347821
                            Click image for larger version  Name:	IMG_5925_01.JPG Views:	0 Size:	310.5 KB ID:	347822
                            Click image for larger version  Name:	IMG_5926_01.JPG Views:	0 Size:	254.0 KB ID:	347823
                            Click image for larger version  Name:	IMG_5928_01.JPG Views:	0 Size:	256.4 KB ID:	347824
                            Click image for larger version  Name:	IMG_5930_01.JPG Views:	0 Size:	200.6 KB ID:	347825
                            Click image for larger version  Name:	IMG_5933_01.JPG Views:	0 Size:	164.8 KB ID:	347826
                            • #74
                              That baby is looking great, also the Roban decals are junk as you said, anyone know a trick to applying the stock Roban decals??, maybe we are doing something wrong, every time I have tried, they just fall apart on me.
                              • #75
                                Hello DCORSAIR, thank you.
                                It's not the installation of the decals that is the problem (I let them soak in a bowl of warm water, then slide them in place.)
                                But the backing of the decals is "pink" and the white, for example, is therefore pink when dry.
                                Another thing: on a mat paint the support is shiny.
                                I have to find the German specialist who had made me "tailor-made" decals (I don't know if my translation is correct) for my Cobra.
                                Yesterday, I remanufactured a 0.5mm thick PETG windshield, i used Roban's as a template.
                                It took me 2 tries to get there.
                                Click image for larger version  Name:	IMG_5935.JPG Views:	0 Size:	102.5 KB ID:	347937
                                Click image for larger version  Name:	IMG_5936.JPG Views:	0 Size:	89.4 KB ID:	347938
                                • #76
                                  Hello ,
                                  News from my UH-1D.....
                                  I finished the replacement of the windshield with the installation of the wipers, the side protections with brass wire and various small things.
                                  I made the pitot tube.
                                  Click image for larger version  Name:	IMG_5937_01.JPG Views:	0 Size:	69.7 KB ID:	349978
                                  Click image for larger version  Name:	IMG_5963.JPG Views:	0 Size:	97.0 KB ID:	349979
                                  Click image for larger version  Name:	IMG_5966.JPG Views:	0 Size:	72.8 KB ID:	349981
                                  I also 3D printed the landing gear fittings
                                  Click image for larger version  Name:	IMG_5965.JPG Views:	0 Size:	128.0 KB ID:	349980
                                  I received the pilot and copilot from WarbirdPilots , but they are "a little" large...
                                  Click image for larger version  Name:	IMG_6003.JPG Views:	0 Size:	79.0 KB ID:	349982
                                  Click image for larger version  Name:	IMG_6001.JPG Views:	0 Size:	82.0 KB ID:	349983
                                  • #77
                                    Hello,
                                    Preparation for the first flight early this morning before the heat.
                                    nothing to say: no vibrations, very quiet.
                                    more than 7 minutes of autonomy.
                                    Unfortunately I was alone at the club, so no video.
                                    Click image for larger version  Name:	IMG_6009_01.JPG Views:	0 Size:	279.8 KB ID:	350483
                                    Click image for larger version  Name:	IMG_6010_01.JPG Views:	0 Size:	285.8 KB ID:	350481
                                    Click image for larger version  Name:	IMG_6011_01.JPG Views:	0 Size:	221.6 KB ID:	350482
                                    • #78
                                      Looks great!!
                                      • #79
                                        Thank's sfcfury
                                        A little additional information:
                                        I found a decal manufacturer who already has a lot of versions in their catalog of the Bell UH-1 at different scales.
                                        • #80
                                          Hello,
                                          Small return on the electronic part and equipment.
                                          After a lot of research I ended up with this:
                                          Hacker A50-12L Turnado V4 450 kV long shaft motor
                                          Controller Jeti Master Mezon 130A Bec
                                          1 Jeti box essential to correctly configure the controller
                                          Flybarless module Bavarian Demon 3X
                                          3 Savöx SA-1256TG 20Kg.cm/6v at cyclic
                                          1 Savöx SC-1258TG 12kg-0.08s at AC
                                          Graupner GR24 Hott Receiver
                                          Optotronix Aurora LCU EVO2 Lighting Module
                                          1 Nimh 5S 3000mAh battery to power the controller's lighting and fan (controlled by a PicoSwitch)
                                          2 x 6S 5200mAh 45C batteries for propulsion.
                                          I return a little more in detail on the controller and the JetiBox:
                                          It's the easiest controller I've had to program, number of motor poles, rotor speed, reduction ratio, brake, etc.... and live measurements.
                                          Click image for larger version  Name:	IMG_5771_01.JPG Views:	0 Size:	143.2 KB ID:	350522
                                          Click image for larger version  Name:	IMG_5774_01 2.JPG Views:	0 Size:	141.0 KB ID:	350523
                                          Click image for larger version  Name:	IMG_5775_01.JPG Views:	0 Size:	143.9 KB ID:	350524
                                          Click image for larger version  Name:	IMG_5772_01.JPG Views:	0 Size:	141.0 KB ID:	350525
                                          Click image for larger version  Name:	IMG_5777_01 2.JPG Views:	0 Size:	141.9 KB ID:	350526
                                          A very practical thing is to have access to the last recorded flight parameters (the photos show a test in the workshop without the blades).
                                          Click image for larger version  Name:	IMG_6020_01.JPG Views:	0 Size:	200.0 KB ID:	350527
                                          - maximum current reached for propulsion (56A during my last flight)
                                          Click image for larger version  Name:	IMG_6012_01.JPG Views:	0 Size:	147.4 KB ID:	350528
                                          - minimum battery voltage
                                          Click image for larger version  Name:	IMG_6016_01.JPG Views:	0 Size:	143.6 KB ID:	350529
                                          - controller temperature
                                          Click image for larger version  Name:	IMG_6013_01.JPG Views:	0 Size:	145.3 KB ID:	350530
                                          - max rotor rpm (1320 rpm during my last flight)
                                          Click image for larger version  Name:	IMG_6015_01.JPG Views:	0 Size:	138.9 KB ID:	350531
                                          - max current delivered by the BEC (6A during my last flight)
                                          Click image for larger version  Name:	IMG_6014_01.JPG Views:	0 Size:	142.2 KB ID:	350532
                                          - battery capacity used
                                          Click image for larger version  Name:	IMG_6017_01.JPG Views:	0 Size:	145.1 KB ID:	350533
                                          - and various programmable alarms....
                                          Click image for larger version  Name:	IMG_6019_01.JPG Views:	0 Size:	152.4 KB ID:	350534
                                          Click image for larger version  Name:	IMG_6018_01.JPG Views:	0 Size:	147.1 KB ID:	350535
                                          My only regret is not to report this info via Hott telemetry (and yes I'm in Graupner / JR) 😪
