Originally posted by sfcfury
View Post
Official Roban 700 Size AH-1W Super Cobra Scale Helicopter ARF Thread
AH-1W Super Cobra Scale 700 Size Helicopter - (Almost Ready to Fly) ARF from Roban - RBN-AH1-7S
Photo credit Adrian Duckenfield
This is the Roban AH-1W Super Cobra Scale 700 ARF. A premium scale kit that offers unparalleled detail. From tip-to-tail the AH-1W body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
This almost ready to fly kit comes with a full scale detail cockpit with dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Full rear cabin interiors are included (not installed). Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The AH-1W really impresses with the highly detailed and accurately scaled down profile.
Features:- 2 Blade rotorhead and scale carbon fiber rotor blades
- 2 Tail blade head and scale carbon fiber tail blades
- Extremely detailed surface with molded panel lines and rivets
- Complete 2 seat scale cockpit
- Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
- Special CCPM mechanics built in the top section like the full scale
- Take off weight of 8kg (approximately double of a 700 3D helicopter)
- 1750mm long, 1/8 scale
- Roban AH-1W Super Cobra 700 scale body
- Full 700 size helicopter mechanics
- 2 Carbon fiber rotor blades
- 2 Carbon fiber tail blades
- Helicopter flight controller - we recommend the BavarianDEMON 3X Flybarless System
- Electronic speed control (ESC) - we recommend the Castle Creations Phoenix Edge High Voltage 160A ESC With Cooling Fan
- Battery eliminator circuit (BEC) - we recommend the Castle Creations 20A BEC Pro
- Brushless motor - we recommend the Scorpion HKIII 4035-560Kv Brushless Motor
- Three cyclic servos - we recommend the MKS HBL665 High Voltage Servo Multi-Pack (3 Servos)
- Tail servo - we recommend the MKS DS HBL980
- 12 Cell 44.4V 5000mAh LiPo battery - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery Multi-Pack in series
- 8 Channel radio - select a minimum 8 channel radio with pitch and throttle curves from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
Class / Size 700 Power Type Electric Rotor Type Collective Pitch Body Material Fiberglass Overall Size (L x W x H) 1870 x 510 x 330mm Flying Weight 8000g Main Rotor Diameter 1560mm Main Rotor Blade Length 700mm Tail Rotor Diameter 280mm Tail Rotor Blade Length 105mm Tail Drive Type Torque Tube Cyclic Servos 3x Metal Gear Tail Servo 1x Metal Gear Power System 530Kv Brushless Motor Electronic Speed Control 120A High Voltage with EC5 Connector Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S) Battery Compartment Size (L x W x H) N/A Required Radio 7 Channel Skill Level Expert Build Time 4+ Hours Recommended Environment Outdoors
