B206 700 Size Helicopter Scale Conversion Kit from Roban - RBN-KF206BW7
This is the Roban B206 News 700 scale conversion kit. A premium scale kit that offers unparalleled detail. From tip-to-tail the B206 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
These scale kits house the cockpit (sold separately) in precisely the right location and are designed to fit your trex 700 mechanics or similar. The B206 really impresses with the highly detailed and accurately scaled down profile.
Originally developed as the YOH-4 for the United States Army's Light Observation Helicopter program, the Model 206 Jetranger was one of the first a generation of light single engine helicopters. Despite a losing the competition, the airframe was redesigned and successfully marketed to both commercial markets as the Jetranger, and military markets as the OH-58 Kiowa.
Commercially, the aircraft is one of the successful and recognizable helicopters ever produced. It has starred in films, served police and fire departments, fought in multiple wars, transported VIPs, flown aerial tours, trained generations of soldiers and Marines to fly, and operated as a medical transport.
Features:
  • Extremely detailed surface with molded panel lines
  • Use of 750MX standard equipment (12S Battery, 530Kv motor), fly with your existing parts
  • Take off weight of 8kg (approximately double of a 700 3D helicopter)
  • 1750mm long, 1/8 scale
Includes:
  • Roban B206 700 body kit
Requires:Important Information - Please Read
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
Class / Size 700
Power Type Electric
Rotor Type Collective Pitch
Body Material Fiberglass
Overall Size (L x W x H) 1870 x 510 x 330mm
Flying Weight 8000g
Main Rotor Diameter 1560mm
Main Rotor Blade Length 700mm
Tail Rotor Diameter 280mm
Tail Rotor Blade Length 105mm
Tail Drive Type Torque Tube
Cyclic Servos 3x Metal Gear
Tail Servo 1x Metal Gear
Power System 1100Kv Brushless Motor
Electronic Speed Control 120A High Voltage with EC5 Connector
Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
Required Radio 7 Channel
Skill Level Expert
Build Time 4+ Hours
