Official 3DP Thread
    T-CAT, great work, Sir. You have me thinking about a better arrangement for the F-18. I would like to move all the PnP items lower in the groove and move the battery tray aft and use the battery better for CG. I just dislike the idea of adding 'dead weight' to achieve proper CG. Possibly some type of threaded adjustable tray where the battery is fixed to the tray and only the tray is moved. Could be reinventing the wheel, however. Best, LB
    Thanks, LB. I appreciate it. I definitely understand where you're coming from about not wanting dead weight. That really is the pitts. Ha-ha. A new adjustable tray would be absolutely fantastic.
    I have attached a pic. of what I did with my Freewing F/A-18C 90mm EDF jet. I moved the battery tray towards the rear, cut out small light wire relief slits in the tray, secured the MCB below the battery tray and used extensions to put the RX closer to the front out of the way of other electronics. Then, I extended the battery compartment by carefully slicing away a new hatch just aft of where the original one ended, relocated the latch and combined both sections via glue and carbon spars to allow for a new longer canopy/cockpit hatch. I was able to place batteries all the way back to the foam bulkhead if needed and depending on the weight of the batteries I intended to use that flight session.
    Don't mind the RX antenna and redundant RX placement in the pic, as none of it was secured yet since it was right after the modding and the picture was taken to show RX placement only.
    Instagram: @tcat.rc.creations
      I did something similar for my Graupner receivers. And the new Mig even has a wood tray already glued into the forward section so it was easy to secure. I made these mainly for my turbines, but works good for the foamies too!
Name:	Graupner RX Mounts.jpg
      Great job, Pat! I love it.
        I really like that setup, simple and secure. Also easy to service if needed
        • Was this site discontinued?
            Elbee commented
            Editing a comment
            Nope. Like you, I have not seen many new posts. Best, LB
        • Well Elbee,
          I promised to include some better pics of my 3D printed Pt Boat back in the spring, before the S hit the fan. Well here they are.... the picture quality is not as good as I had hoped for, used my old phone.... The boat uses 3 out runners, 4mm shafts, and props from the designer. I re-designed the motor mounts from 1 for each per motor, to a 3 motor mount incorporated into a single mount, All the internal equipment is set on risers that insert into donuts on the floor. All equipment can be removed for servicing. The hull is open all the way, front to back, with a bilge pump at the stern. The esc's are 30 amp, water cooled, all are fed from a 3s2p Lipo.... Could go to 4s2p if needed..... The most difficult part, of this project, was coming up with the crew figures. They are sliced and diced from all over the internet.
          This project has been a lot of fun, but now I'm looking forward to heading to the lake for some fun. later, MikeClick image for larger version  Name:	Pt 010.jpg Views:	0 Size:	139.4 KB ID:	284683Click image for larger version  Name:	Pt 002.jpg Views:	0 Size:	57.7 KB ID:	284684Click image for larger version  Name:	Pt 003.jpg Views:	0 Size:	56.1 KB ID:	284685Click image for larger version  Name:	Pt 007.jpg Views:	0 Size:	151.3 KB ID:	284686Click image for larger version  Name:	Pt 001.jpg Views:	0 Size:	157.6 KB ID:	284687Click image for larger version  Name:	Pt 006.jpg Views:	0 Size:	154.2 KB ID:	284688Click image for larger version  Name:	Pt 008.jpg Views:	0 Size:	146.9 KB ID:	284689Click image for larger version  Name:	Pt 005.jpg Views:	0 Size:	164.7 KB ID:	284690Click image for larger version  Name:	Pt 004.jpg Views:	0 Size:	150.9 KB ID:	284691Click image for larger version  Name:	Pt 009.jpg Views:	0 Size:	167.5 KB ID:	284692Click image for larger version  Name:	Pt 000.jpg Views:	0 Size:	190.5 KB ID:	284693
            Elbee commented
            Editing a comment
            W45, She's a real beauty. Bravo Zulu, Sir. Best, LB
        • I have 2 projects in the works. One I hope to have flying this week assuming I can get the CG figured out. The other I hope for spring
          • Fantastic work Dee.
            • Just picked up an elegoo Saturn for detailed prints. Any advice for someone new to resin printing?
              • Originally posted by Gilatrout View Post
                Hey GT, Set up a ventilated cleaning station or area for sure . Patience will be required when curing out the parts. Great addition to your shop. Looking forward to seeing your prints. Best, LB
                Captain: Got any ideas?
                F/O: Actually not.
                • The Lippisch flies . I'm planning on getting some more flying on it this weekend, as the maiden was a quick outing during my lunch break from work. It was a bit pitch sensitive, so the maiden was a bit brief. I hope to nail down the CG and control throws this weekend and wring it out. I'll be posting the STLs to cults3d shortly after.
                  • Getting closer on my MG-15 remix for the He111. I'm amazed how stupid thin a resin printer can print.
                    This one is still too fragile to mount in the model. I designed it so I could remove the barrel for transport. I'm going to have to add some reenforcement to the receiver side that will also provide a gluing surface for the gun.
ID:	291585Click image for larger version
