The Official Hobby Squawk Code of Conduct
This is a sticky topic.
  • #61
    Originally posted by tengarang View Post
    @ George not sure how to reply to your comment directly so i repost here
    "You mean competitors don't you?"
    which is why i ask in the first place if it would be ok to post affiliate links. I see links in this forum referencing other vendors outside of MRC as well, so yes the links i post could be from a competitor if they are relevant to my posts.
    im seeking to clarify this issue
    Im looking for a simple yes its ok or no its not ok feedback
    I hit comment instead of quote...I would think you could...post it and see, when have you ever been shy:P
    • #62
      There is no set rule against affiliate linking per se as long as it pertains to the particular post/subject matter.
      In other words, if you wanted to link to a random plane or spare part or accessory we do not carry and is the subject of your post/thread, that is fine. However, having affiliate links as part of your global signature is not allowed.
      Hope that clears the matter up for you.
      • #63
        Roger that my man understood;)always appreciate your evaluation
        FAILURES ARE ONLY UNDERDEVELOPED SUCCESSES
        https://www.pinterest.com/tengarang/edf-warbirds
        • #64
          Thank you sire crystal clear
          Acknowledged
          one last bit of uncertainty which i will extrpolate to all other spheres of influence before i make my executions,
          lets say a 5000mah 55c 3s pack is being referenced
          can i post if mrc has this itm out of stock assuming the discharge c rating is not exactly 1:1?
          or should i not think about this approach and steer clear of it all together, i dont want to hurt your business intentionally
          • #65
            Yep, you bet. What we are trying to avoid are obvious attempts to advertise our direct competitors in a spammy, aggressive manner, i.e. "Don't forget to check out ABC Hobby for all your accessory needs!"
            • #66
              This is well understood will conduct my postings with accordance to these guidelines and avoid such examples
              thank you
