How long will it last
  • How long will it last
    I was just wondering what kind of time one might get out of a 3300mah battery on the Apprentice? I know that the throttle percentage is the main thing but I was just curious to see if you fine folks might have some idea.
    Still Learning:D
    RE: How long will it last
    You are correct in that it depends on throttle management; however, some report 15 minutes and above using your size battery. Hope this helps.
      Thank You Pheonix for your reply back. That's what I was thinking just wondering what kind of maximum flight time I might be able to get.
      Still Learning:D
        As an update, I flew the 3s 3300mAh this weekend with a student and with throttle management we landed after 12 minutes with a consistent reading in the 3.75v-3.77 range per cell.
          Thia is about the time my fellow pilots are getting with this set-up.
            Thank you! My instructor was wanting to go for 6 to 7 at the most and I was thinking if we went with about a 50% throttle I could maybe stretch a little longer. After a 7 flight I still had about a 50% battery!
            Still Learning:D
