I have been working on an LX Models Mig29 KIT for the past three weeks. I have been having several major issues with their design and was wondering if anyone has dealt with these issues. This jet does not come with wing spars. To add the wing spars would be great, but the landing gears are in the Fuselage, and occupy the space adjacent to the wing mounts. As the landing gears are in retracted position, there is no room for the spars to enter the fuse without hitting the LG. I have seen videos of this Mig29 on YouTube, where the wing snaps off during flight due to lack of a wing spar. I also wanted to know if anyone has had CG issues because of battery placement. The manufacturer recommends to use two 3S 4000 mah batteries in Series. The plane has two separate compartments for the batteries, one being near the nose of the plane and the other just behind the canopy. I have seen some Youtube Videos where the pilots have used just one 6S 4000 mah battery in the rear compartment. I would prefer to use the latter, with just one battery, however I am not sure if it would cause CG issues. The stock LX twin 70mm EDF motors are nice and light, but are garbage. Instead I am planning to use twin FMS 1850KV 2860 inrunner motors that are slightly heavier. One of the major flaws of this model is that the fuselage comes in two halves. The top half, which the LG is mounted on and the bottom half, that incorporates all the servo and esc wires. Once you glue the two halves together, there is no way to do any modification. So it's important to check all systems before permanently gluing the two surfaces together. I will post photos of the build shortly.
