SonicModell Skyhunter 1800mm (70.8") - PNP from ZOHD - ZOH10036
This full scale 1800mm wingspan Skyhunter is the most classical FPV airframe for long time, long distance and heavy load FPV flying. The unique twin-boom tail wing design makes the Skyhunter very stable in the air, the 1800mm large wingspan provides a high efficiency elevating force, the spacious cabin offers plenty of room inside the fuselage for FPV gear and up to a 15,000 mah battery for extremely long flight times. More than 14 carbon fiber strips and rods enhance the wing and body for durability and strength during your flights. It’s detachable main wing and tail makes the Skyhunter easy for disassembly for transport.
Easy Assembly and Transport Detachable main wing and tail boom, glue-free assembly, portable for outdoor flying. |
Durable EPO Construction Molded by tough EPO material, built-in CF spar for enhancement, stable flying capability and impact resistance. |
Large Battery Bay The Skyhunter incorporates a large battery bay for extended flight time. |
Long Flight Times The large wingspan helps support long time FPV flying in a variety of weather conditions. |
- Lightweight with the potential for more than 100 minutes of flying time with larger batteries
- Tough EPO material with carbon fiber enhancement, high-strength fuselage and wing
- Large wingspan for long time FPV flying in variety of weather conditions
- Large size cabin for more FPV equipment and larger batteries
- Unique large nose pod for multiple cameras
- Detachable main wing and tail for easy transport
- Fast disassembly structure and adjustable tail boom length, easy to adjust CG
- Strong carbon fiber support for main wing and tail wing
- ZOHD SonicModell Skyhunter 1800mm (70.8") - PNP
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 5000 - 15000 mAh LiPo Battery or 4 Cell 14.8V 5000 - 15000 mAh LiPo Battery - we recommend the Admiral 5000mAh 4S 14.8V 40C LiPo Battery with XT60 Connector
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOUR
Wingspan | 1800mm / 70.8in |
Length | 1400mm / 55.1in |
Weight (w/o battery) | 3500g / 123.4oz |
CG (Center of Gravity) | Refer to manual |
Power System | 2820-920kV Brushless Outrunner Motor |
Electronic Speed Control | 60A |
Propeller / EDF | 11x7 |
Servos | 3x 12g metal gear |
Landing Gear | N/A |
Required Battery | 3 Cell 11.1V 5000-15000 mAh LiPo Battery for 3S or 4 Cell 14.8V 5000-15000 mAh LiPo Battery for 4 Cell (required) |
Required Radio | 4 Channel (required) |
Ailerons | Yes |
Elevator | Yes |
Rudder | Yes |
Flaps | No |
Lights | No |
Hinge Type | Foam |
Material | EPO Foam |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoor |
