Official ZOHD 860mm SonicModell Nano Talon EVO - PNP Thread
  • Official ZOHD 860mm SonicModell Nano Talon EVO - PNP Thread
    SonicModell Nano Talon EVO 860mm (33.8") - PNP from ZOHD - ZOH10053-001
    An updated version of the Nano Talon! Now introducing the 860mm Wingspan Nano Talon EVO, which is more than just a "straight wing version" of the original one. It comes with many great features like having a bigger NACA air intake to keep all your electronics nice and cool. Built-in carbon fiber spar and extended plywood tray, bigger room to place your 18650 or additional FPV gear. GPS slot, crash-resistant and easily assemble are just some of the few features why the Nano Talon EVO is a must-have!
    Easy Assembly and Transport
    The detachable wing and vertical fins makes the Nano Talon EVO easy to transport.
    Durable, Impact-Resistant
    The Nano Talon EVO is molded in durable EPP, built-in CF spar for enhancement, stable flying capability and impact resistance.
    Large Battery Bay
    The Nano Talon EVO incorporates a large battery bay for your chosen FPV equipment and electronics.
    Camera Compatibility
    The multi-camera nose is compatible with 99% of the FPV and HD cameras in the market: Runcam HD, 2, 3S, Swift, Split, GoPro H4-5-6-7, Session, and much more!
    FEATURES:
    • EPP molded wing, built-in CF spar for enhancement, light, flexible and crash-resistant
    • Straight wing instead of an anhedral wing to get a more stable and agile attitude
    • Updated SunnySky motor with a longer shaft, compatible with regular propellers
    • Updated 9g servos from plastic gear to metal gear
    • Updated ESC from 30A with 5V 1A Linear BEC to 30A with 5V 2A Switch BEC
    • Detachable main wing and tail wing for easy transport, easy to install. Improve connections for better aileron and tail stability
    • Enlarged battery bay for Lipos from 3S to 4S, and Li-Ions 18650 4S 2P 3500mAh
    • Bigger NACA air-inlet provides more air cooling for your FPV gear inside the fuselage
    • Built-in carbon fiber spar and extended plywood inside the fuselage for more strength in case of an impact
    • Optional belly mapping camera bay and camera mount for mapping
    • Texture marked on both sides of fuselage for a more secure hand launch grip
    • Optional Teflon cover for fuselage bottom, super durable, protecting the fuselage bottom from scratches on landing
    INCLUDES:
    • ZOHD SonicModell Nano Talon EVO 860mm (33.8") - PNP
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Wingspan 860mm / 33.8in
    Length 570mm / 22.4in
    Weight (w/o battery) N/A
    CG (Center of Gravity) Refer to manual
    Power System 2204-1870kV Brushless Outrunner Motor
    Electronic Speed Control 30A
    Propeller / EDF 6x3
    Servos 9g metal gear
    Landing Gear N/A
    Required Battery 4 Cell 14.8V 1300-2200 mAh LiPo Battery (required)
    Required Radio 4 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material BEPP Foam
    Skill Level Intermediate
    Build Time 1 Hour
    Recommended Environment Outdoor
