Originally posted by Simon Bee
View Post
Official Freewing de Havilland DH-112 Venom V2 90mm EDF Jet
OK great , just ordered a light from MRC. I was thinking I’d have to link it to the gear channel on the receiver as well as setting it up on the transmitter.Originally posted by Rocky9 View PostYes the light turns on when the landing gear is lowered. Plug the light connector into the channel I have circled in green on the LED controller pic.
Great thanks very much for that 👍👍 Just one more question, does the light come on when the gear is lowered and if so how do you set it up ? I can’t find any instructions for that light controller.
It wasn't too bad of a mod, I used my Dremel to gut a U shape in the fwd gear door and screwed the light right to the plastic. The wiring can be fed up through the gear well and back to the LED Light Controller box. The tension spring is not strong enough to lift the door with the added weight of the light, so I zip tied the wire to the strut for now, I'll need to come up with a way to mechanically link the door to the strut. I used the 5W LED light offered by Motion. https://www.motionrc.com/collections...00mm-lead-e612Originally posted by Simon Bee View Post
Nice !!! Can you let me know what you used to do that ?
Just Googled it, sort of understand what it does now.Originally posted by Simon Bee View PostSorry about being a bit dumb about this but what does the UBEC do ?
Can I plug the UBEC lead into the bind channel or do I need to get a Y splitter and plug it into one of the other channels?
Just building mine now and I’ve come across something I’ve not seen before UBEC. I’ve got a 6 channel Spektrum AR637T for it but after you’ve connected all 6 servos, where does the UBEC connect to ?
I don't know. Seems to be some conflicting information. RC Castle currently is selling both the red and silver one and both come with 9-blade fan, 1900kv, INrunner.Originally posted by Tigerman View PostMotion RC on the Web site advatise the Venom now with 9 blade inrunner motor. So is that wrong and they are still being sold with 90mm outrunner motor???
There seems to have been 3 versions of this plane. The original was the "Ready2Fly" V1 with the outrunner 1450kv fan with a 5 blade. Then came the red Swiss V2 and the silver V3. Both the V2 and V3 have the inrunner 1900kv fans in them, however, there appears to be misprints in the descriptions. In the first post of this thread, James indicated that it has the 12-bl, 1450kv fan as a V2 - something's not right about this. I have the red V2 and just looked down the hole and I see the 12-bl in there, undoubtedly with the 1900KV inrunner. The 1450kv was in outruner.
The original V1 flew nice but it was a bit sluggish for such a "largish" plane. My current red one is a lot peppier with loads of low end grunt - gets off the ground much quicker. It also looks a lot faster in the air. The sound of the 12-bl (more jet like) is far more pleasing than the old 5-bl (more vacuum cleaner like).
Had the silver Venom with old 90.mm outrunner motor in the model I notice the Venom now has an inrunner motor now. Decided it is time have this model back in my fleet. I remember it flew so well and the sound was great. Just wanted to know what difference the inrunner motor makes compared to my old Venom with outrunner motor. How different if any does the inrunner version to my old Venom with the outrunner
First EDF, Habu. Second Rebel, Third Avanti and I think the Venom is the next.
Thought I might buy the silver and paint it to RAF Cold War colours.
- Likes 2
Control Throws for the Venom.
Alpha I purchased the Silver V3 of the Venom a week or 2 ago.
There is absolutely no mention of suggested control throws in the manual.
Out the box the current throws (high rate and no expo) up 25 mm --> down 23mm, Ail Up 36mm --> down 34mm (measured at the inner most point of the ail) Rudd 22mm left and 22mm right.
The elevator and aileron travel seems way to excessive compared to some of my other Freewing aircraft?
Can you please either update the online manual and/or post the suggested throws in mm or inches here.
Thanks in advance
Chris
Glad to hear that yours never folded. (cough) :)Originally posted by xviper View PostI've had 3 of these. The first 2 were silver and now I have the red one. The second silver one I had aileron servo reversed and it rolled over upside down and crashed hard. The wing spars were NOT an issue. Sure, the wings move (flap up and down) a bit but that doesn't seem to be a problem. All 3 of mine do that.
Well that's disappointing. I was hoping they would improve the wing spar or something.
