Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
Maybe I missed it, but did Motion mention if the F35 has any plastic edge reinforcements? -
Come over at the end of August for our jets over Monarto jet meeting. Totally free and heaps of Vics making the trip, plus I will be flying several of my conversions, including my latest creation! It's the large Freewing B2 bomber fitted with a X45.Leave a comment:
Agree, but I did mention that in my post. I much prefer to convert a existing EDF myself as I have all the tools to make my own pipes and tanks. I have lost count of the number of conversions that I have done, but probably around 35 jets!Leave a comment:
Many years ago, I converted my 70mm version to X45 turbine but soon changed out to Jetcat P20, which was better suited. I flew it for about 10 flights and then sold it as I was having trouble seeing it! This larger version will be perfect for a X70 turbine, so hope that a version without the EDF will be an option in the future. I know that a turbine version is on the cards, but I already haves pipes and tanks ready to go. https://youtu.be/RSqqYQfZ0NQ?si=MAxQ8iOZm5VlZ-ScLeave a comment:
Turbine, yes; shortening the vertical stabilizers, probably not. It would likely negatively affect the flight characteristics, which could be noticeable at low speeds. I won't do that, because in my opinion it doesn't need to be an absolute scale model, but it should definitely fly well!YASSSS!
Re 'turbine version', I'll take care of that myself. I LOVE converting these FW foamies! As far as the way-too-big verticals, given the fact that they're not rounded off, there's no reason I can't take a razor and 'fix' them, right? Sharp blade, sealer and some paint, and we're good!
I'm thinking an X-60. I'd be able to get enough fuel in there for a 12-minute flight! Is it late summer yet???
YASSSS!
I'm thinking an X-60. I'd be able to get enough fuel in there for a 12-minute flight! Is it late summer yet???Leave a comment:
😀Ah, good ! The conversion to a kerosene turbine will be simpler than for MIG or EF! No need for a bifurcated tube! 😀Leave a comment:
Very nice... bravo Freewing and Motion RC!!!! We need things like this so we jet pilots don't get bored and have to invest our money in stocks! The motor is incorrectly labeled in the text; the KV value is correct in the table below. I'll definitely be getting one of these for my hangar as soon as it's available in Europe (Switzerland).
The F-35C Lightning II is the U.S. Navy's carrier variant of the most advanced stealth strike fighter ever built. Designed specifically for carrier operations, the F-35C features the largest wings of the three F-35 variants, distinctive folding wingtips for below-deck storage, and a reinforced airframe built to withstand the extreme demands of catapult launches and arrested landings. As the Navy and Marines' only fifth-generation strike fighter, the F-35C combines stealth, advanced sensor fusion, and supersonic performance in a platform that defines modern carrier aviation.
The Freewing F-35C Lightning II Super Scale 110mm EDF Jet is the largest model Freewing has ever produced, and it delivers the scale fidelity and features expected from their most ambitious release. Powered by an all-new high-performance 110mm EDF unit, this model commands the flight line with serious thrust and an authoritative presence that suits the scale and significance of the aircraft. Its precisely sculpted stealthy fuselage, accurate F-35C wing geometry make this one of the most faithful large-scale representations of the Lightning II ever produced.
The feature list is exceptional. CNC-machined shock-absorbing struts, scale painted gear legs, and sequenced landing gear doors deliver the kind of ground presence and realistic operation you'd expect from a much larger and more expensive model. Factory-installed scale LED navigation, formation, and nose gear landing lights illuminate the airframe, while an included afterburner LED system delivers a glowing exhaust effect at full throttle that turns heads on the flight line and during every high-speed pass. Quick-release plug-in wings for fast, tool-free assembly and a factory-installed EG01 gyro complete the package — delivering a refined, confidence-inspiring flight experience from the very first takeoff.
Three distinct livery options span both U.S. Navy and U.S. Marines F-35C operations. The VFA-147 Argonauts (tail #406) delivers the clean, muted gray look of a front-line carrier jet in low visibility trim. The VMFA-251 Thunderbolts (tail #01) brings bold orange-yellow lightning bolt markings on a striking dark tail, while the VFA-101 Grim Reapers (tail #101) features the iconic skeleton figure with dramatic red accents. Each model ships with factory-applied common markings and a custom decal set — apply your squadron's signature details straight from the sheet, or use the clean airframe as a canvas for your own custom scheme.
Freewing’s Biggest & Best
The F-35C is the largest and most feature-loaded model Freewing has ever produced to date. Scale landing gear, sequenced gear doors, afterburner LEDs, scale navigation lighting, quick-release wings, and a factory gyro combine to deliver a level of scale realism and flight refinement that pushes every boundary at this size class.110mm. Every Millimeter Earned.
The all-new 110mm 12-blade EDF unit at the heart of the F-35C isn't just the largest fan Freewing has ever put in a model — it's the engine behind everything this aircraft delivers. Raw thrust, turbine-like sound, and the kind of performance that matches the scale of the jet it powers.Gear Down. Sequence Complete.
When the gear comes down on this model, it shows. CNC-machined shock-absorbing struts, scale painted gear legs, and finely detailed undercarriage components combine to deliver the kind of ground presence that makes the F-35C look every bit as purposeful sitting on the ramp as it does in the air.Three Liveries. Each One Legendary.
Choose from the operational low visibility scheme of VFA-147 Argonauts (tail #406), the bold orange-yellow lightning bolt markings of VMFA-251 Thunderbolts (tail #01), or the iconic Grim Reaper skeleton figure with dramatic red accents of VFA-101 (tail #101). Each model ships with factory-applied common markings and a custom decal set — apply your squadron's signature details straight from the sheet, or use the base markings as a canvas for your own custom scheme.Confidence at Scale
The factory-installed gyro stabilization system smooths the flight envelope and aids precision on approach, making the F-35C more locked in, without taking anything away from the model’s high-performance character.Light Up The Sky
Factory-installed navigation and formation LEDs illuminate key positions across the airframe, while the included afterburner LED system delivers a glowing exhaust effect at full throttle. Whether flying at dusk or making a low-speed pass down the runway, this model makes an impression every single time.Fast to the Flight Line
Quick-release plug-in wings mean the F-35C goes from transport to flight faster than you’d expect from a model this size. Less time assembling, more time flying — exactly how it should be at the field.Features:The F-35C Look — Done Right
The F-35C has one of the most distinctive silhouettes in modern aviation — a carefully shaped stealth airframe where every surface serves a purpose. This model captures that presence faithfully, from the broad carrier wings and blended fuselage contours to the characteristic nose profile, canted twin tails, and the subtle angular geometry that defines the Lightning II's stealthy identity.- Freewing's largest and most feature-rich model produced to date
- Powerful 110mm EDF delivers authoritative jet performance worthy of the F-35C
- Three authentic liveries: VFA-147 Argonauts low viz (U.S. Navy), VMFA-251 Thunderbolts color (U.S. Marines), VFA-101 Grim Reapers color (U.S. Navy)
- Sequenced landing gear doors open and close in true scale sequence
- Enhanced scale LED lighting package includes navigation lights, formation lights, and nose gear landing lights for impressive realism on the ground and in the air
- Included afterburner LED system illuminates the exhaust at full throttle for stunning realism
- Painted, scale, CNC-machined shock-absorbing struts deliver realistic ground presence and smooth operation
- Quick-release plug-in wings allow fast, tool-free field assembly and disassembly for convenient transport and storage
- Pre-installed and programmed Freewing EG01 6-axis gyro for an even more refined flight experience
- Precisely sculpted stealthy fuselage with accurate F-35C wing geometry and scale surface detail
- Durable EPO foam construction with carbon fiber reinforcement throughout
- Factory-installed digital metal gear servos for precise, reliable control response
- Spacious battery bay accommodates a wide range of 12S pack sizes
- Factory-installed 3658-2150Kv brushless inrunner motor and 130A ESC optimized for 12S high-performance flight
- Detailed cockpit with scale interior and hand-painted pilot figure
- Model officially licensed by Lockheed Martin
- Freewing F-35C Lightning II 110mm EDF Jet – PNP w/Gyro (your choice of livery)
- Factory-installed 110mm EDF unit with high-performance 3658-2150Kv brushless inrunner motor
- Factory-installed 130A High voltage electronic speed control (ESC), with 10A UBEC
- Scale electric retractable landing gear with sequenced gear doors (installed)
- Factory-installed gyro stabilization system
- Scale LED navigation and formation lighting system (installed)
- Afterburner LED system (installed)
- Detailed cockpit with pilot figure
- Carbon fiber wing spars and structural reinforcement
- Quick-release plug-in wings for transport and storage
- Instruction manual
- 6-9 Channel radio (7 required for reverse thrust, 8 required for gyro mode selection, 9 required for formation light on/off) — select a minimum 6 channel radio from our Radio Collection
- 6-9 Channel receiver (7 required for reverse thrust, 8 required for gyro mode selection, 9 required for formation light on/off) — select a minimum 6 channel receiver from our Receiver Collection
- 2x 6 Cell 22.2V 6000mAh LiPo batteries with EC5 connector — we recommend the Admiral Pro 6000mAh 6S 22.2V 50C LiPo Battery with EC5 Connector Multi-Pack (2 Batteries)
- 6-cell compatible battery charger depending on battery selection – select a minimum 6 cell (6S) charger from our Charger Collection
AGE LEVEL : 14 and Up
SKILL LEVEL : Intermediate
BUILD TIME : 1+ Hours Model Scale 1/9.8 Scale Wingspan 1340mm / 52.8in Length 1618mm / 63.7in Weight 6700g–7000g / 236–247oz CG (Center of Gravity) 133–140mm measured from the leading edge where the removable wing panel meets the fuselage Power System 4678-680KV inrunner motor (included) Electronic Speed Control 130A High Voltage with 10A UBEC (included) Propeller / EDF 110mm EDF, 12-blade (included) Servos 14x digital metal gear servos (included) - 9g Digital Hybrid servo x5
- 17g Digital Metal Gear servo x6
- 30g Metal Gear servo x2
- 9g Metal Gear servo x1
Landing Gear CNC-Machined aluminum, shock absorbing, retractable landing gear (included) Required Battery 2x 6 Cell 22.2V 5000-6000mAh LiPo for 12S operations (required) Required Radio 6-8 Channel minimum (7 required for reverse thrust, 8 required for gyro mode selection) Ailerons Yes Elevator Yes Rudder Yes Flaps Yes Lights Yes — Nav/Formation + Afterburner Brakes Thrust Reversing Gyro Yes Hinge Type Nylon Material EPO Foam with carbon fiber reinforcement Skill Level Intermediate Build Time 1+ Hours Recommended Environment Outdoors Recommended Runway Surface Hard and soft surfaces, including maintained grass runways
Let's agree they should have paid more attention to the verticals, they stand out as too big.Leave a comment:
Let's put it this way you aren't going to be invited to the World Jet Masters Flying a Foam EDF Jet no matter how scale it is.
Let's all agree it's just fun scale to be flown and enjoyed.
Warbirdfan29,
Yep, I agree and figured as much.
I used the reference that was used as an example and supplied by MotionRC.
Also, agree with you about compromises to scale for an easier to fly model.
As a model subject, the F-35C is current, though not my cup of tea; however, I do appreciate the time, talent, and engineering that went into this project.
Best, LB
Hello Elbee, that is not a Freewing print photo! This side view is from another source. Fyi. Compare it with the Freewing pictures an you´ll see the difference! :-)Warbirdfan29,
Grabbed a 3-view off the interweb of a F-35C from Aviation's Militaries.
Opened PowerPoint, inserted the 3-view from Aviation's Militaries.
Inserted the picture you have referenced via copy/paste and resized that to the approximate length of the 3-view side profile.
I don't see a difference.
Doesn't mean the model is the same as the Freewing stock photo, but there ya go.
Best, LB
Many thanks for the extensive feedback regarding the enlarged rudders. I fully understand that modifications to RC models—deviating from the full-scale aircraft—are sometimes necessary. However, in my view, the enlargement of the rudders on the new Freewing F-35C is too conspicuous, compromising the model's scale appearance. I am basing this judgment on my own observations and the many photos of the actual aircraft available. Anyone who isn't bothered by this should feel free to buy the F-35C; it is certainly a solid choice. Personally, I don't care for it, so I will be skipping this model and looking forward to the next new release.Leave a comment:
No worries boys...... You don't have to like it LOL.... I'll take your jet lol. I agree it is not 100%, but when I saw it in person, I really wasn't bothered by it a whole lot. It flew pretty solid, which maybe the reason they had to slightly change the scale look was to make it more stable in flight possibly. None the less, I know I'll be ordering 1 or maybe 2. So hold off on your ordering let me get my 2 first since you don't like it as much LOL. I'll fly it.Leave a comment:
