Official XK Model 290mm A200 F-16 with Gyro Thread
  • Official XK Model 290mm A200 F-16 with Gyro Thread
    A200 F-16 with Gyro 290mm (11.4") Wingspan from XK Model - (Ready-To-Fly) - RTF - WLT-A200
    The XK Model A200 F-16 RTF is a great introductory jet model aircraft for beginners due to its built-in stability system (3D/6G) that supports smooth flights and resistance to crashes.
    The powerful brushed motor supports a wide flight envelope for flying everything from stable flight to impressive aerobatics. The XK Model A200 F-16 boasts attractive scale looks in the iconic thunderbirds scheme. If you are looking to get into the hobby with a smaller jet with a built-in gyro for stability and nice scale looks the XK Model A200 F-16 would be a terrific choice.
    • Comes with 3D/6G, a gyro for increased stability and helps decrease the chance of a crash. Simply cycle between 6G (stable mode) and 3D (no control surface limits) by pressing the aileron stick to the lower left after activating the model
    • Made of EPP material, lightweight, high flexibility and crash-resistant
    • Compact size and nice scale looks appeals to both novice and advanced pilots
    • Powerful brushed motor supports a wide flight envelope from stable to aerobatic flight
    • XK Model A200 F-16 with Gyro 290mm (11.4") Wingspan - RTF
    • FTR Futaba S-FHSS Compatible 4CH 2.4GHz Transmitter
    • 2.4GHz Receiver
    • 1S 3.7V 300mAh LiPo Battery
    • 1S LiPo Battery Charger
    • USB Charging Cable
    • Replacement Propeller
    • Owner's Manual
    Requires:
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
    Product Specifications:
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: None
    Model Scale N/A
    Wingspan 290mm / 11.4in
    Length 330mm / 12.9in
    Weight 46g / 1.62oz
    CG (Center of Gravity) Refer to the manual
    Power System 2x Brushed motors (included)
    Electronic Speed Control N/A (included)
    Propeller / EDF 2x pusher propellers (included)
    Servos Micro
    Landing Gear fixed (included)
    Required Battery 1 Cell 3.7V 300mAh LiPo battery (included)
    Radio 2.4GHz (included)
    Ailerons No
    Elevator Yes
    Rudder No
    Flaps No
    Lights No
    Hinge Type Nylon
    Material EPP Foam
    Skill Level Beginner
    Build Time None
