Wiring 1600mm Spitfire
    It is possible that one of the light circuits on the board is bad. Try using a Y and plug both into the same pins and see if both work. You can use a proper 3 pin Y, just make sure you plug the 2 pin light lead into the proper 2 pins in the Y end and the same goes for when you plug the Y into the board. Ensure the +/- go into the proper pins, meaning the signal pin doesn't go into a pin on the corresponding side. If this works, then of course, both lights will do the same thing but at least both work.
    As for the flaps, you should also set your wing type to something like 1 flap, normal tail to open up the flap menu and assign the proper switch to control it. You will have to play with things like "sub-trim" on the flap channel to help zero the flaps and also the percentages in the flap menu.
  • Zman
    Thank you xviper....I have not tried bypassing the blue box with the flaps but, I will do that. and No, with the lights... either one works and the other doesn't.... try moving them and then the other wing light comes on and the other does not. very strange.
    Do you have the control board diagram? Have you tried to bypass the blue box with the flaps and plug one into the flap port on the receiver? If it works, try the other one. If they both work, use a Y instead of going through the board. Do all the lights work but just not "properly"? Could you have one or more burnt out light?
    Page 6 ------ https://cdn.shopify.com/s/files/1/10...1600spitV2.pdf
  • Zman
    Thank you Kallend. I appreciate the response.....I double, triple and quadruple checked the positive/negative leads. I put the labeled wires into the blue box as the instructions say.....not working correctly. I have moved them around in every configuration that I know and still can't get both wing lights to work properly.... I am at wits end...
  • kallend
    Check that the servo plugs are inserted the right way round in the blue box. It's easy to get one side wrong.
    Actually the top light was not a flashing beacon, it was a signal lamp for when radio silence was required. There was a morse key in the cockpit.
    I have Arduino code for flashing messages in morse if anyone is interested. Here is one installed in my Lancaster:
  • Zman
    started a topic Wiring 1600mm Spitfire
    Hello, my Name is Mike, most call me Zman.... I have a question about the 1600mm Spitfire IX....I just purchased it and am trying to wire it up but, either the top white strobe light stays on always instead of blinking or only one side of the the wing lights light up and also the Flaps will not work. I have tried every combination of putting the wires into the blue box trying to follow the directions but, the lights and flaps never seem to work.... the blue box clearly says what should be plugged into each port but, still... the lights and flaps do not work properly... all else works fine..the ailerons, landing gear, elevator, tail and steering....I am pulling my hair out with this...(and I don't have much hair left so....) any help would be greatly appreciated.
    Zman
