Official Black Horse 2668mm L-60 Brigadýr Discussion Thread
  • Official Black Horse 2668mm L-60 Brigadýr Discussion Thread
    L-60 Brigadýr 2668mm (105") Wingspan - ARF from Black Horse - BHM1025-001
    The Black Horse L-60 Brigadýr brings the distinctive look and versatile flying qualities of this classic Czech utility aircraft to life in an impressive giant-scale ARF. With a generous 2668mm (105") wingspan and a lightweight balsa-and-plywood structure, the Brigadýr delivers smooth, stable flight characteristics and a commanding presence in the air.
    Expertly constructed from all balsa and plywood, the airframe is covered in a high-quality, heat-shrink printed film that provides a clean, scale appearance straight out of the box. The large wing area, NACA airfoil, and well-balanced design contribute to predictable handling and relaxed flight manners, making the Brigadýr well suited for scale cruising, smooth approaches, and graceful landings.
    Power system flexibility is a key strength of this design. The L-60 Brigadýr supports 30–35cc gasoline engines or electric power systems in the 2500–3200W range, allowing builders to tailor the setup to their preferred flying style. Robust oleo-strut landing gear is included for both the main gear and tail gear, providing reliable ground handling and durability on grass runways.
    With its classic lines, forgiving flight behavior, and large, easily accessible airframe, the Black Horse L-60 Brigadýr is an excellent choice for pilots looking for a distinctive giant-scale aircraft that emphasizes stability, realism, and enjoyable everyday flying rather than extreme performance.
    Commanding Giant-Scale Presence
    With a massive 105" wingspan, the L-60 Brigadýr makes an immediate statement. Its broad stance and authentic proportions deliver the unmistakable presence of this classic design only a true giant-scale model can provide.
    Scale Landing Gear, Built In
    Shock-absorbing landing gear is included to handle the demands of a large airframe. Designed for smooth ground handling and confident operations, it complements the model’s size and weight perfectly.
    Power System Freedom
    Configured to support both 30–35cc gas engines and powerful electric setups, the Brigadýr gives you true flexibility. A roomy internal layout keeps installations clean, accessible, and adaptable to your preferred power system.
    Efficient, Builder-Friendly Assembly
    High levels of prefabrication reduce build time without sacrificing quality. Pre-hinged control surfaces, a factory-covered airframe, and quick-release plug-in wings make transport, assembly, and setup fast and straightforward so you spend less time building and more time flying.
    • Massive 1:5 scale design with a commanding 2668mm (105”) wingspan
    • Lightweight, strong, precision laser cut balsa and plywood construction
    • Two-piece, plug-in wings with quick-release simplify transportation and assembly
    • Heat-shrink film covering with factory-printed scale details for added realism
    • Robust scale landing gear with shock absorbing struts included for reliable ground handling
    • Aluminum spinner included for scale appearance and balance (included)
    • Optimized for gas engines (30–35cc) or powerful electric outrunners (up to 3500W) (not included)
    • Spacious fuselage interior simplifies installation of power system, radio gear, and batteries
    • NACA airfoil wing design promotes smooth handling and predictable control response
    • Pre-hinged control surfaces for easy assembly
    • Large cabin windows and greenhouse canopy enhance scale realism and visibility
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass control horns
    • Comprehensive control and fitting accessories included
    • Black Horse L-60 Brigadýr 35cc 2668mm (105") Wingspan - ARF
    • Main and tail landing gear with shock-absorbing struts
    • Painted cockpit with pilot figure and interior details
    • Aluminum spinner spinner
    • Comprehensive hardware, linkage, and fitting accessories
    • Detailed assembly and instruction manual
    Requires (Electric):Requires (Gas):Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 12+ Hours
    Model Scale 1/5 Scale
    Wingspan 2,668mm / 105in
    Length 1,672mm / 65.8in
    Weight 8kg / 17.6lbs
    CG (Center of Gravity) 92mm as measured from the wing root leading edge aft
    Power System 175Kv Brushless Outrunner Motor or 35cc 2 or 4-stroke (required)
    Electronic Speed Control HV 85+ amp (required for electric)
    Propeller / EDF 21x13 for electric, 20x8 for gas (required)
    Servos 7x HV high torque
    Landing Gear Scale landing gear with oleo struts (included)
    Required Battery 2x 6 Cell 22.2V 5000 - 6000 mAh LiPo batteries in series (required for electric)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Nylon Heavy Duty pin hinges
    Material Balsa and Plywood
    Skill Level Intermediate
    Build Time 12+ Hours
    This looks very cool and different. So what size radial will
    fit under the cowl? Love the see pics of the inside of the airframe and wing attachment hardware.
      Very interesting and seldom modeled aircraft!
