Hi all, I'm new to this site and have an issue with my Liberator, for some reason she has dropped the bind and refuses to re bind despite following all the protocols. She was purchased as a BNF version with rx pre installed, the transmitter is a DX 18. She has flown twice previously with no issues.All lipo's and tx batts fully charged, tried binding at various distances, I have 25 years of experience with IC models so not a novice. Any help greatly appreciated.
B 24 Liberator bind issues
What RX is in it? Knowing this may give a clue as to what might be going on. (BTW, there is no BNF version. It's whatever RX the previous owner put in it.) Was it flown twice previously by you or the previous owner? What I'm trying to get at is if you've ever flown it on your equipment?
The B-24 came with dual battery plugs. Depending on what sequence you use to plug them in, may dictate how well it all initializes. One plug has the UBEC attached to it. That one should be plugged in first and the other one plugged in as quickly as possible after the first one.
As said before, throttle trim to the bottom. Did you ever do the ESC throttle calibration?
Hi Viper, the liberator arrived with pre installed Rx from Motion Rc, no previous owner. And yes if you read my post you will see that i have flown the model, and yes i am aware of the sequence of lipo connection. Rx is AR6210. As said previously, i am not a novice and i am aware of throttle position during binding process. Calibration was set up when it arrived, i have flown it twice as previously mentioned.
Originally posted by Paul. K View PostHi Viper, the liberator arrived with pre installed Rx from Motion Rc, no previous owner. And yes if you read my post you will see that i have flown the model, and yes i am aware of the sequence of lipo connection. Rx is AR6210. As said previously, i am not a novice and i am aware of throttle position during binding process. Calibration was set up when it arrived, i have flown it twice as previously mentioned.
Originally posted by Paul. K View PostIf its any help guy's the UBEC has a solid red light when connected to lipo's but Rx is non responsive. Basically the model lost its bind and i am trying to re bind it with no luck at all. I suspect that the Rx is faulty.
Originally posted by xviper View PostThen you should also know that the B-24 does not normally come as a BNF. Motion put that AR6210 into it because that's what they thought you wanted. They don't even sell Spektrum RXs. In any case, a 6210 is not anything special. Put in bind plug, power it up in whatever fashion you like, TX to bind. If it's not binding, something's up with the RX. Try a different RX just to see.
Must apologize, the model was PNP on further inspection, bought it several years ago from Motion rc and forgot!. Yes i know that the receiver is nothing special, i never assumed it was.
Originally posted by Gilatrout View Post
This is the first I've heard on motion including a receiver in the B24. I find it extremely odd that it is a spectrum and not admiral part as motion does not sell any horizon hobby products.
That's your best next step. Those old 6xxx series Spektrums were quite rudimentary.
Yes i agree, i have a new 8 series Spektrum receiver in my giant scale Stearman that i know works just fine. This should eradicate one possible cause if i transfer it to the Liberator. If that does not work then i will be stumped!. Will keep you posted, thanks for advice.
