1/275 Scale Chinese Destroyer 780mm (30.7") - RTR from Bancroft - BNC1053-001
Affordable to own, easy to operate, and enjoyable to display, these R/C replicas from Bancroft deliver a model that is equally at home on display on your bookshelf or sailing on a nearby pond. Details like armament, aircraft, helicopters, and flight operations support equipment are included to provide additional realism. Along with the ship and display stand, a transmitter, rechargeable battery pack and convenient USB charger complete the contents of the package. Simply add two AA batteries (not included) for the transmitter, charge the battery pack, and you can be sailing one of these warships yourself!
A new destroyer design was originally started by Russian shipbuilders in the 1970s, employing a new 130mm automatic gun turret.
This class of ships were 156 meters (512 ft) in length, with a beam of 17.3 meters (56 ft 9 in) and a draft of 6.5 meters (21 ft 4 in).
The Chinese Navy had commissioned two modified Russian Sovremenny-class destroyers, with the Hangzhou (after which this replica is modeled) delivered in December 1999. In 2002, they ordered two improved versions designated 956-EM. The first vessel was launched in late 2005, while the second was launched in 2006. All were commissioned to the East Sea Fleet.
Recreated in 1/275 scale and resulting in a model over 30” (780mm) long, this vessel is ideally suited for display or sailing.
Included Scale Accessories The model comes with armament, a helicopter, and other accessories resulting in a model that you’ll be proud to own and operate. Unlimited possibilities exist for additional painting and weathering details to be added by the owner. |
Contra-Rotating Propellers and Safety Shut-Off The efficient twin-screw propulsion system delivers scale operation, and safety is assured for younger skippers. The propellers automatically cease rotating when the ship is removed from water. A convenient touch-switch allows testing of the ship in dry dock with a finger. |
Unsurpassed Value Significant numbers of factory-installed details and accessories add to realism never before seen at this price point. |
Convenient USB Charging A simple USB charger allows use of computer, device charging block, or alternate source of USB power. Automatic charge termination guarantees a complete charge every time! |
- Completely assembled and ready to sail
- Perfect for display or R/C operation
- Includes 7.4v, 1500mAh rechargeable battery pack, convenient USB charger, and 2.4GHz transmitter
- Unique safety feature automatically stops propeller when vessel is removed from the water
- Includes display/maintenance stand as well as additional aircraft and deck details
- Bancroft 1/275 Scale Chinese Destroyer 780mm (30.7") - RTR
- 2.4GHz Pistol-Grip Transmitter
- Rechargeable Battery Pack
- USB Charger
- Deck Details and Accessories
- Instruction Manual
- Two (2) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :1 hour
Scale | 1/275 |
Length | 780mm / 30.7in |
Width | 95mm / 3.7in |
Height | 215mm / 8.3in |
Hull Material | Plastic |
Battery | 7.4V 1500mAh Li-Ion |
Battery Quantity | 1 |
Battery Connector | Tamiya-type |
Motor | Brushed |
Motor Quantity | 2 |
Propeller Material | Plastic |
Contra-Rotating Propeller | Yes |
ESC | 2-in-1 |
ESC Waterproof | Splash-Proof |
ESC Quantity | 1 |
Radio | Pistol grip |
Receiver Channels | 2 |
