Super Mono X V2 Brushless 360mm (14.2") Racing Boat from Bancroft - RTR - BNC1033-001
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
The Bancroft Super Mono X V2 Brushless delivers the speed and razor-sharp handling that only a mono-hull design can produce in a convenient, Ready To Run (RTR) package. Open the box, charge the included battery with the provided charger, your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for balanced speed and maneuverability out of the box without any additional adjustment. The Bancroft Super Mono X V2 Brushless sports a menacing, stealth-like black trim scheme that accentuates its speed and performance potential.
Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Super Mono X can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 3S battery, and battery charger.
Water-Cooled Brushless Power Instantaneous acceleration and unsurpassed reliability are delivered by the included brushless water-cooled outrunner motor, coupled to an efficient 2.3mm flex-cable drive system. |
Extraordinary Running Hardware A CNC-machined aluminum rudder provides precise control and handling, while stainless steel ride plates and turn fin allow the Super Mono X to be tuned for maximum performance in any water conditions! |
Included Boat Stand A convenient boat stand allows you to display or maintain the Super Mono X when in dry dock. |
Self-Righting Function Run in confidence knowing that should your boat capsize from excessive chop or wind; the innovative self-righting function automatically returns your craft to upright and ready to return to shore. |
- RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
- All Electronics are pre-installed
- Fully Painted and Decorated
- Zero assembly required --Get underway in minutes!
- Rated for ponds or calm lakes appropriate for RC Boats
- Bancroft Super Mono X V2 360mm (14.2") Racing Boat - RTR
- 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
- Brushless, water-cooled motor drive system, pre-installed, with XT60 battery connector
- Steering servo, pre-installed
- 3S 11.1V 1800mAH LiPo Battery
- 3S Battery Charger
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH - we recommend Admiral AA NiMH 2600mAh rechargeable batteries
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :15 minutes
Scale | N/A |
Length | 360mm / 14.2in |
Width | 120mm / 4.7in |
Height | 120mm / 4.7in |
Hull Material | ABS |
Battery | 3S 11.1V 1800mAH LiPo Battery |
Battery Quantity | 1 |
Battery Connector | XT60 |
Motor | Brushless, water-cooled |
Motor Quantity | 1 |
Propeller Material | Nylon Composite |
Contra-Rotating Propeller | No |
ESC | 30A Brushless, Water-cooled |
ESC Waterproof | Yes |
ESC Quantity | 1 |
Radio | Wheel |
Receiver Channels | 4 |
