Magic Vee V5 Micro 225mm (8.9") Racing Boat from Bancroft - RTR - BNC1028-001
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
Easy to drive, the Bancroft Magic Vee delivers the speed, control, and style needed to rule the pool or pond in a convenient Ready To Run (RTR) package. Open the box, charge the included battery with the included charger, insert your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for balanced speed and maneuverability out of the box without any additional adjustment. The Bancroft Magic Vee sports a slick racing scheme, accented by race-inspired decals.
Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Magic Vee can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 2S battery, and battery charger. Only four AA batteries are required to begin racing!
High Performance Equipment Impressive acceleration and sustainable high speeds are delivered by a water-cooled marine 180 motor and reliable micro marine ESC. The included 2S 320mAh LiFePO4 battery and convenient USB charger deliver high performance and extended run times! |
CAD-Designed Hull The Magic Vee’s ABS plastic hull is digitally-optimized to deliver outstanding performance and razor-sharp handling in compact areas like pools and small ponds. A convenient boat stand is also included for when the Magic Vee is in dry dock! |
Durable Running Hardware Including features usually found only on larger and more costly boats, the Micro Vee has a flex-shaft prop drive and adjustable turn fin that allows you to dial-in the boat for any operating environment or water condition. |
Micro-Size, Macro-Performance Don’t let the compact size and economical price fool you, the Magic Vee is fast, agile, and enormously fun to drive! Grab a pair and race your buddies in most any swimming pool or small pond. |
2.4GHz Pistol Grip Transmitter A reliable, interference-free radio system ensures that the Magic Vee is always under your control at distances of up to 100M (300’). |
Easy To Transport Take the Magic Vee V5 Micro anywhere with big power in a small package. |
- RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
- All Electronics are pre-installed
- Fully Painted and Detailed
- Zero assembly required --Get underway in minutes!
- 2.4Ghz radio system and all electronics Pre-Installed
- Extensively detailed and hand finished
- Rated for calm ponds, pools, and lakes appropriate for RC Boats
- Bancroft Magic Vee V5 Micro 225mm (8.9") Racing Boat - RTR
- 2.4Ghz Radio and Receiver, pre-installed
- Brushed water-cooled motor drive system, pre-installed, with JST battery connector
- Steering servo, pre-installed
- 2S 6.4V 320mAh Battery
- 2S Battery Charger
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH - we recommend Admiral AA NiMH 2600mAh rechargeable batteries
AGE LEVEL :14 and up
SKILL LEVEL :beginner
BUILD TIME :15 minutes
| Scale | N/A |
| Length | 225mm / 8.9in |
| Width | 70mm / 2.8in |
| Height | 70mm / 2.8in |
| Hull Material | ABS |
| Battery | 2S 6.4v 320mAh LiFePO4 |
| Battery Quantity | 1 |
| Battery Connector | JST |
| Motor | 180 brushed, water-cooled |
| Motor Quantity | 1 |
| Propeller Material | Nylon Composite |
| Contra-Rotating Propeller | No |
| ESC | 5A |
| ESC Waterproof | Splash-Proof |
| ESC Quantity | 1 |
| Radio | Wheel |
| Receiver Channels | 2 |
