Official Bancroft Smart Cat 360mm Offshore Catamaran Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is impressive, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    Rule the pool or perform on the pond with the compact Bancroft Smart Cat. At 360mm (14.1”) long, she’s large enough to handle mild choppy water yet maneuverable enough to operate in a pool. The catamaran hull design delivers the best attributes of both deep-V and hydroplane design, resulting in a quick, agile model.
    The molded ABS plastic hull arrives factory-decorated, with a 2.4GHz pistol-grip transmitter, water-cooled brushed motor, combination ESC/receiver, 9g micro rudder servo, and more. The durable composite nylon rudder provides precision steering control, while the main deck and hatch assembly features a water-resistant gasket. The included 7.4V 900mAh Li-ion battery pack with convenient USB charger delivers high speeds and extended run times. This model is so complete, it even includes 4 AA dry cells for the transmitter. There is nothing else to add except water!
    Outstanding Onboard Electronics
    The Smart Cat features a 9g micro rudder servo for precise control in addition to a neoprene deck gasket to keep electronics free from moisture.
    Durable Running Gear
    The nylon composite rudder and mount assembly provide durability with precision control, while the flex cable driveshaft delivers optimum power to the two-bladed propeller.
    Pistol Grip 2.4GHz Transmitter
    The Smart Cat features a modern, lightweight, and comfortable pistol grip transmitter for fatigue free ergonomics and interference-free control. Trims and steering rates are independently adjustable.
    Water-cooled Brushed Motor
    The 390-class brushed motor features a water-cooling jacket for improved efficiency and reliability.
    Features:
    • RTR (Ready to Run) with 2.4GHz radio
    • All Electronics are factory-installed
    • Fully painted and decorated
    • Convenient molded boat stand
    • 7.4V 900mAh Li-ion battery pack
    • USB Charger
    • Includes transmitter batteries
    Includes:
    • Bancroft Smart Cat 360mm (14.1”) Offshore Catamaran - RTR
    • Factory-installed 2.4Ghz radio, ESC/receiver, and rudder servo
    • Convenient boat stand
    • 7.4V 900mAh Li-ion battery pack and USB Charger
    • AA dry cells for transmitter (4)
    Requires:
    • Nothing else to buy-everything is included!
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 10 Minutes
    Scale N/A
    Length 360mm / 14.1in
    Width 125mm / 4.9in
    Height N/A
    Weight 480g / 17oz
    Hull Material ABS
    Battery 7.4V 900mAh Li-ion
    Battery Quantity 1
    Battery Connector XT60
    Motor 390 brushed
    Motor Quantity 1
    Propeller Material Plastic
    Contra-Rotating Propeller N/A
    ESC 15A
    ESC Waterproof Splash-proof
    ESC Quantity 1
    Radio 2.4GHz pistol grip
    Receiver Channels 2
