Official Bancroft Motion DV 950mm (37.4”) Extreme Deep Vee Discussion Thread
  • Official Bancroft Motion DV 950mm (37.4”) Extreme Deep Vee Discussion Thread
    Click image for larger version  Name:	bancroft-motion-dv-950mm-37-4-extreme-deep-vee-racing-boat-rtr.webp Views:	0 Size:	101.1 KB ID:	422158
    Version Info: This boat is delivered as "Ready-to-Run", however does require 4x AA batteries for the transmitter, two 2S (or two 3S) LiPo batteries and a battery charger, purchased separately (see Requires below for details).
    Enjoy the thrills of high performance RC boating with Bancroft’s new Motion Deep Vee, a 950mm (37.4”) long rocket ship that handles so precisely that it makes even newer boaters look like experts! Powered by a 1300kV water-cooled brushless outrunner motor with a robust flexshaft drive system, the Motion DV can be powered by 2 x 2S packs for 4S operation or 2 x 3S packs for 6S operation that is breathtakingly fast! Two propellers are included to maximize performance on either choice of battery packs. A Hobbywing-made 90A water-cooled ESC delivers smooth, efficient throttle control to effectively harness the battery power, while a reliable 2.4GHz pistol grip transmitter offers comfortable control.
    Included adjustable aluminum turn fins and trim tabs allow the Motion DV to exceed 50MPH on 6S power in calm water, but probably the key feature of the new Motion DV is its self-righting feature! No longer must you worry about capsizing your high performance boat in the middle of your pond. With this feature, simply allow the ballast tank to fill (a few jolts of reverse can help) and wait about 30 seconds for the boat to roll upright! Driving forward empties the ballast tank and you’re on your way once again.
    Combine the performance and handling of Bancroft’s Motion DV 950mm (37.4”) Extreme Deep Vee RTR with Motion RC’s industry-leading technical, parts, and customer service support for an unforgettable RC experience.
    Premium Running Hardware
    The Motion DV features a polished metal propeller with anodized aluminum rudder, rudder bracket, and driveshaft mount.
    Reliable Brushless Power
    The brushless 1300kV water-cooled outrunner motor will propel the Motion DV to speeds over 50MPH (83KPH) with the proper setup on 6S battery configuration.
    Easy Battery Installation
    The Motion DV uses a “saddle pack” battery configuration to place a 2S or 3S battery on each side of the hull. This provides proper lateral balance for the best possible handling.
    Self-Righting System
    The ample size of the Motion DV’s self-righting tank allows for fast recovery from the inevitable flip or roll-over during high speed runs or when crashing waves.
    Convenient Hatch Lock
    The upper hatch of the Motion DV is secured by a system of interconnected latches controlled by one handle. A convenient graphic reminds you to lock the hatch before running!
    2.4 GHz Control
    The Bancroft 2 channel pistol grip radio is lightweight and delivers hours of comfortable operation.
    • Durable blow-molded ABS composite hull with attractive factory-applied graphics
    • Stable, fast deep-vee hull design with adjustable trim tabs and turn fins for extreme performance and razor-sharp handling
    • Includes 2.4GHz pistol grip radio system
    • High-torque rudder servo with metal gears
    • Anodized aluminum and alloy running hardware
    • Water cooled brushless motor and electronic speed control
    • Heavy-duty, water-cooled marine ESC capable of 6S operation (and with reverse!)
    • Convenient self-righting function — no longer any fear from blow-overs!
    • Includes metal props for 4S or 6S operation
    • Protective boat stand included—great for display and maintenance
    • Batteries and battery charger not included
    • Bancroft Motion DV 950mm (37.4”) Extreme Deep Vee Racing Boat - RTR
    • 2.4GHz transmitter
    • Boat stand
    • 4S and 6S propellers
    • 2 XT90 connectors (DIY if required)
    • Instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 20 Minutes
    Scale N/A
    Length 950mm / 37.4in
    Width 260mm / 10.2in
    Height 210mm / 8.3in
    Hull Material ABS
    Battery 2 x 2S 7.4V 5000mAh OR 2 x 3S 11.2V 5000mAh LiPo batteries with XT90 connectors
    Battery Quantity 2
    Battery Connector XT90
    Motor 1300kV brushless outrunner
    Motor Quantity 1
    Propeller Material Metal
    Contra-Rotating Propeller No
    ESC 90A
    ESC Waterproof Yes
    ESC Quantity 1
    Radio 2.4GHz pistol grip
    Receiver Channels 2
    Biggest mistake I ever made was buying this boat!!
      The guy who owns the hobby shop were I brought the boat to be assembled didn’t know what most of the parts were for
