Official ROC Hobby 1/18 Scale Magnum 4WD Crawler RTR Thread
    • 8233
    Magnum 1/18 Scale 4WD Crawler RTR by ROC Hobby - FMS11814RTRGN
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
    The 1/18 scale Magnum from ROC Hobby is a highly detailed, fully capable RC replica, ideal for the trail or display. Unmistakable styling cues capture the sense of American pride and style during the post-war late 1940’s and early 1950’s. The vintage shape of the detailed, injection-molded body is complimented by chrome grilles, bumpers, and mirrors while the remotely operable LED headlight, brake light, and turn signal system adds unsurpassed realism. The operable cargo bed tailgate allows for realistic cargo loading and unloading, while the opening hood allows access to electronics and scale appeal. Inside, the truck features a scale cab with realistic dashboard and seats, while a wide side-step extends under the doors. In addition, a flat one-piece front windshield and spacious rear window provide an impressive view of the scale interior.
    With aluminum frame rails, four-link suspension, high-torque crawler motor, and grippy multi-terrain tires the Magnum is an ideal multi-purpose off-road vehicle. The transmitter features a switchable option to change gears for smooth, slow crawling performance during incline or traversing crawls, downhill departures, or other extreme conditions. In addition, the included 7.4V 2S Lipo battery provides up to 30 minutes of non-stop action on a charge!
    Combine the versatile, go-anywhere fun of the Magnum 1/18 Scale 4WD Crawler RTR with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Molded Hard Plastic Body
    The vintage shape of the detailed, injection-molded body is complimented by chrome grilles, bumpers, and mirrors.
    Aluminum Frame Rails
    Metal chassis rails anchor a proven link-style suspension for maximum grip, axle articulation, and steering response.
    Opening Tailgate
    The operable cargo bed tailgate allows for realistic cargo loading and unloading!
    Water-Resistant Electronics
    Operate in confidence thanks to the Magnum’s waterproof electronics.
    Features:
    • Chassis-mounted servo
    • Aluminum frame rails
    • Injection-molded hard plastic body
    • Rhino bumper kit
    • Functional hood and scale interior features
    • Scale interior features
    • High-traction tires with 1.0 inch internal bead lock wheel
    • Realistic pinion & ring gear axle
    • High torque transmission with 104:1 FDL
    • 4GHz radio with water-resistant electronics
    • High-torque over-sized 55T brushed crawling motor
    • 4V 2S Lipo battery provides up to 30 minute run time
    Includes:
    • ROC Hobby Magnum 1/18 Scale 4WD Crawler - RTR
    • ROC Hobby 2.4GHz transmitter
    • 2S 7.4v 380mAh LiPo battery
    • USB charger
    • Instruction Manual
    • Tools
    Requires:
    • 4x AAA alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :none
    Model Scale 1/18
    Length 328mm / 12.8in
    Width 149mm / 5.8in
    Height 125mm / 4.9in
    Weight (No Battery) 570g / 20.3in
    Wheelbase 196mm / 7.6in
    Ground Clearance 38mm / 1.5in
    Body Molded hard plastic, factory painted and decorated
    Chassis Composite with metal rails
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 56mm (2.19”) x 19.2mm (0.75”)
    Wheel Hex Size 7mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel, solid axle
    Shock Type Spring dampers
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 104:1
    Pinion N/A
    Spur Gear N/A
    Differential No
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control 2-in-1 RX/ESC
    Motor Mini 050 brushed
    Battery 2S 7.4V 380mAh LiPo
    Servos 3-wire, 1Kg waterproof
    Radio 2-Channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
