Official Roban 700 Size AH-64 Apache Green Scale Helicopter ARF Thread
    • 8231
    AH-64 Apache Green 700 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-AH64-7S
Name:	Roban website hero.png
    This is the Roban AH-64 Apache Green 700 ARF. A premium scale kit that offers unparalleled detail. From tip-to-tail the AH-64 body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
    This kit comes with a full scale detail cockpit with dashboard, joysticks, rudder pedals, aerials, windshield wipers and more. Floor and ceiling details can be crafted so once the interiors are installed you have an impressively scaled cockpit/interior.
    These scale kits house the cockpit in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The AH-64 really impresses with the highly detailed and accurately scaled down profile.
    Features:
    • 4 Blade rotorhead and scale carbon fiber rotor blades
    • 4 Tail blade head and scale carbon fiber tail blades
    • Extremely detailed surface with molded panel lines and rivets
    • Complete 2 seat scale cockpit
    • Comes with Hellfire missiles, Hydra 70 rockets, M230 chain gun
    • Complete built In / partially pre-installed position lighting system (Controlled via AUX channel)
    • Special SM2.0 mechanics built in the top section like the full scale
    • Take off weight of 8kg (approximately double of a 700 3D helicopter)
    • 1750mm long, 1/8 scale
    Includes:
    • Roban AH-64 Green 700 body kit
    • Full 700 size helicopter mechanics
    • 4 Carbon fiber rotor blades
    • 4 Carbon fiber tail blades
    • Complete 7 seat scale cockpit
    Requires:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Expert
    BUILD TIME: 4+ hours
    Class / Size 700
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1910 x 620 x 435mm
    Flying Weight 8500g
    Main Rotor Diameter 1560mm
    Main Rotor Blade Length 700mm
    Tail Rotor Diameter 280mm
    Tail Rotor Blade Length 105mm
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 450Kv Brushless Motor
    Electronic Speed Control 120A High Voltage with EC5 Connector
    Recommended Battery 2x 6S 22.2V 5000 mAh LiPo with EC5 Connector (in series for 12S)
    Required Radio 7 Channel
    Skill Level Expert
    Build Time 4+ Hours
