This is the Roban MD-500E Black 700 scale conversion kit, a premium scale kit that offers unparalleled detail. From tip-to-tail the MD-500E body kit displays an accuracy of detail to the real aircraft not normally seen in the RC helicopter hobby.
These scale kits house the cockpit (sold separately) in precisely the right location and the mechanics are built into the engine compartment just like in the full scale version. The MD-500E really impresses with the highly detailed and accurately scaled down profile.
Features:
- Extremely detailed surface with molded panel lines and rivets
- Use of 750MX standard equipment (12S Battery, 530Kv motor), fly with your existing parts
- Take off weight of 8kg (approximately double of a 700 3D helicopter)
- Roban MD-500E Black 700 body kit
- 700 Size helicopter kit - we recommend the Phoenixtech Flasher 700 helicopter Kit
- Helicopter flight controller - we recommend the BavarianDEMON 3X Flybarless System
- Electronic speed control (ESC) - we recommend the Castle Creations Phoenix Edge 130A ESC with 5A BEC
- Battery eliminator circuit (BEC) - we recommend the Castle Creations 20A BEC Pro
- Brushless motor - we recommend the Scorpion HKIV 4025-1100Kv Brushless Motor
- Three cyclic servos - we recommend the MKS HBL665 High Voltage Servo Multi-Pack (3 Servos)
- Tail servo - we recommend the MKS DS HBL980 Tail Servo
- 6 Cell 22.2V 5000mAh LiPo battery - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery
- 8 Channel radio - select a minimum 8 channel radio with pitch and throttle curves from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
Product Specifications:
AGE LEVEL: 18 and up
SKILL LEVEL: Expert
BUILD TIME: 4+ hours
| Class / Size | 700 |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Fiberglass |
| Overall Size (L x W x H) | 1670 x 480 x 610mm |
| Flying Weight | 8000g |
| Main Rotor Diameter | 1360mm |
| Main Rotor Blade Length | 700mm |
| Tail Rotor Diameter | 280mm |
| Tail Rotor Blade Length | 105mm |
| Tail Drive Type | Torque Tube |
| Cyclic Servos | 3x Metal Gear |
| Tail Servo | 1x Metal Gear |
| Power System | 1100Kv Brushless Motor |
| Electronic Speed Control | 120A High Voltage with EC5 Connector |
| Recommended Battery | 6S 22.2V 5000 mAh LiPo with EC5 Connector |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 7 Channel |
| Skill Level | Expert |
| Build Time | 4+ Hours |
