Official Roban 600 Size UH-1N Rescue Scale Helicopter Conversion Kit Thread
    • 8231
    UH-1N Rescue 600 Size Helicopter Scale Conversion Kit from Roban - RBN-KFUH1NRES6
    The UH-1N Twin Huey is a twin-engine military helicopter. A member of the numerous Huey family, it first flew in 1969. The UH-1N has a fifteen-seat configuration, with one pilot and fourteen passengers. This is the 600 size UH-1N Rescue version. Designed to take your Chaos 600 or Trex 600ESP torque tube versions* and transform it into a very scale RC version of the full scale helicopter. This kit includes everything you need to install your mechanics, including the 45 degree angle raised tail gearbox specially designed for easy plug-n-play install in the Chaos or Align mechanics.
    These 600 scale conversion kits from Roban offer special designed side frames which are designed to offer 2 primary special features. One is to lower the transmission which allows the torque tube to travel thru the lower tail boom of the helicopter which has always been a problem with most military helicopters. Probably the most revolutionary design in scale helicopters, these frames allow the entire mechanical system to be tucked up inside the dog house just like the full scale helicopters.
    No more mechanics taking up the entire fuselage area leaving no room for cockpits, rear seats, etc.
    Most of the work is done for you. All wood work is installed. Pre-drilled holes for easy install of the landing gear. The optional scale cockpit is completely hand assembled and painted for you in impressive detail. All you need to do is just slide it in place. Decals no more! The cockpit is hand painted with raised details and instruments.
    Because the UH-1N Twin Huey is a 2 blade helicopter, there is no need to change any configuration within the mechanics. If you have an existing good flying 600 helicopter, you will not need to upgrade or change anything. Standard 600 set up is an 1100 Kv brushless outrunner motor, 80-100 amp ESC and a 6S 22.2V 5000 mAh or higher LiPo battery.
    This fuselage can be completed in as little as 4-6 hrs and is intended for the intermediate to advanced builder.
    Features:
    • Fully painted fiberglass scale fuselage
    • Magnetic cabin lock system for quick and easy access
    • Extremely detailed surface and molded panel lines
    • Use of 600 standard equipment (6S Battery, 1100Kv motor), fly with your existing parts
    Includes:
    Roban UH-1N Rescue 600 body kit
    • Scale landing skids
    Requires:Optional:Important Information - Please Read
    Product Specifications:
    AGE LEVEL: 18 and up
    SKILL LEVEL: Advanced
    BUILD TIME: 4+ hours
    Class / Size 600
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1480 x 330 x 280mm
    Flying Weight 3000g
    Main Rotor Diameter N/A
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Torque Tube
    Cyclic Servos 3x Metal Gear
    Tail Servo 1x Metal Gear
    Power System 1100Kv Brushless Motor
    Electronic Speed Control 130A High Voltage with EC5 Connector
    Recommended Battery 6S 22.2V 5000 mAh LiPo with EC5 Connector
    Required Radio 7 Channel
    Skill Level Advanced
    Build Time 4+ Hours
