Link to purchase:
EC-135 Super Scale 450 Size GPS Stabilized Helicopter - RTF from RotorScale - RSM-450-R-EC-N137AM
Bring life-saving air-medical realism to the skies with the EC-135 Medic 450 Size GPS-Stabilized Helicopter. Inspired by the helicopters trusted worldwide for emergency and rescue operations, this model captures the urgency, professionalism, and unmistakable presence of real-world air-medical flight. From its clean, modern lines to its detailed medic livery and mission lighting, the EC-135 delivers a scale experience that feels purposeful and authentic every time it lifts off.
Built around RotorScale’s proven GPS-stabilized flight system and a purpose-designed 450 size mechanical layout, the EC-135 450 blends high-fidelity scale modeling with confident, accessible control. The streamlined fuselage, simulated fenestron tail, and four-blade rotor head work together to create a professional, authentic scale presence that looks right both in the air and on the ground.
Advanced GPS stabilization actively holds both altitude and position, allowing pilots to experience realistic air-medical missions with confidence and ease. Features such as Return to Home provide added reassurance during flight, while a switchable underside spotlight enhances scale realism and brings authentic search, rescue, and medical mission character to every sortie.
Arriving completely Ready to Fly, the EC-135 Medic includes everything needed to get airborne, making it an ideal choice for pilots seeking true-to-life civilian helicopter scale realism paired with steady, GPS-assisted control.
Visit the Official RotorScale EC-135 Super Scale 450 Size GPS Stabilized Helicopter Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
Features:
AGE LEVEL : 14 and Up
SKILL LEVEL : Intermediate
BUILD TIME : 10 Minutes
| Ready for the Mission The EC-135 Medic arrives fully set up and Ready to Fly. Simply install the main blades, charge the battery, add 4 AA transmitter batteries, and take to the skies in minutes. |
| Advanced GPS Stabilization Advanced GPS stabilization actively holds both altitude and position, allowing pilots to experience realistic air-medical missions with confidence and ease. |
| Four Blade, Flybarless Rotor Head The four blade, flybarless rotor head delivers smooth, stable flight characteristics while enhancing the EC-135’s realistic scale appearance. |
| Simulated Fenestron Tail A six blade tail rotor driven by a brushless motor simulates the fenestron design, enhancing scale appearance while providing smooth, reliable tail control. |
| Functional Medic Spotlight A switchable underside spotlight adds visual interest and enhanced visibility, complementing air medical and search oriented flight profiles. |
| Professionally Finished and Highly Detailed Fiberglass Fuselage The professionally painted fiberglass fuselage features crisp panel lines and detailed surface features for a clean, realistic EC-135 appearance. |
| Realistic LED Lighting Integrated LED lighting enhances scale authenticity and improves visibility during early morning or late evening flights. |
| Authentic EC-135 Scale Presence Balanced proportions, a multi-blade rotor system, and refined detailing give the EC-135 Medic a true-to-life, professional presence that looks right both in the air and on the ground. |
- Completely Ready to Fly package includes everything needed to start flying right away, just add 4 AA transmitter batteries
- Advanced GPS stabilization delivers rock solid, steady, beginner friendly flight performance
- 450 size airframe provides excellent stability, efficiency, and realistic presence in the air
- Switchable underside spotlight enhances scale realism for air medical, search, and rescue style operations
- High quality, professionally painted fiberglass fuselage molded with panel lines and detailed scale surface features
- Realistic LED lighting system enhances authenticity and improves visibility during flight
- Four blade rotor head delivers smooth flight characteristics and true scale realism
- Simulated fenestron style tail with a six blade prop driven by a brushless motor for realistic appearance
- Three selectable flight modes adapt to pilot skill level, including GPS Mode, Angle Mode, and Manual traditional helicopter Mode
- Return to Home and auto land function ensures safe, easy recovery, especially for newer pilots
- Carbon fiber frame construction provides excellent rigidity while remaining lightweight
- Brushless main and tail motors deliver high efficiency, smooth power, and long term reliability
- Reliable 2.4GHz control system ensures solid, interference free connectivity
- RotorScale EC-135 Super Scale 450 Size GPS Stabilized Helicopter – RTF
- 2.4 GHz Transmitter
- Flight Battery
- Charger
- Instruction Manual
- Four (4) AA batteries for the transmitter
BUILD TIME : 10 Minutes | Class / Size | 450 Size |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Fiberglass |
| Overall Size (L x W x H) | 750mm (29.5 in) x 155mm (6.1 in) x 240mm (9.5 in) |
| Flying Weight | 1545g (3lb 6.5oz) with battery |
| Main Rotor Diameter | 745mm (29.3 inches) |
| Main Rotor Blade Length | 335mm (13.2 inches) |
| Tail Rotor Diameter | 86mm (3.4 inches) |
| Tail Drive Type | 3500Kv Brushless Outrunner Motor |
| Cyclic Servos | 3x 12g, Digital, Metal Gear Servos |
| Tail Servo | N/A |
| Power System | 2820 1300Kv Brushless Motor |
| Electronic Speed Control | 60A, 2-in-1 ESC |
| Recommended Battery | 4S 3000-4500mAh LiPo Battery - EPR40004X6 |
| Required Radio | 2.4GHz Radio (included) |
| Skill Level | Intermediate |
| Build Time | Less than 10 minutes |
