Official RotorScale 120 Size MD-500 Defender “PAF” Gyro Stabilized Helicopter RTF Discussion Thread
  • Official RotorScale 120 Size MD-500 Defender “PAF” Gyro Stabilized Helicopter RTF Discussion Thread
    MD-500 Defender “PAF” 120 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1025-001
    The RotorScale MD-500 Defender brings one of the most recognizable light attack helicopters to life in a compact 120 size ready-to-fly scale package. With its distinctive fuselage, striking Philippine Air Force (PAF) camouflage finish, and scale weapon pods, this Defender captures the aggressive presence of the full-scale helicopter in stunning miniature detail.
    Equipped with a scale 4-blade flybarless rotor head, the MD-500 delivers smooth, precise handling while maintaining authentic scale appearance. A 6-axis gyro and optical flow positioning system provide rock-solid stability, keeping the helicopter steady in hover or forward flight even for less experienced pilots. One-touch auto takeoff and landing simplify the most challenging parts of flight.
    With its factory-applied scale finish, beautifully molded panel line and rivet detail, and LED lights, this MD-500 Defender looks every bit as authentic as it flies. Best of all, it arrives completely ready-to-fly with transmitter, battery, charger, and accessories included—just add four AA batteries, and you’re ready for your first mission.
    Aggressive Battlefield Detail
    From its distinctive fuselage shape to the factory-applied Philippine Air Force camouflage, the MD-500 Defender radiates combat presence. Molded rivet and panel details, plus optional shark mouth decals, make this heli look every bit as fierce as the full-scale.
    Ready-to-Fly In Minutes
    No building, no setup headaches—everything you need is included. The transmitter, battery, charger, and helicopter come pre-configured, so you can go from box to flight line in minutes. Just charge the LiPo, install four AA batteries in the transmitter, and launch your first mission with total confidence.
    Scale 4-Blade Flybarless Rotor
    The MD-500’s 4-blade flybarless rotor head delivers smooth, stable performance while maintaining authentic scale appearance. Each hover and maneuver feels realistic, giving you precision control wrapped in scale detail.
    6-Axis Gyro with Optical Flow
    Flight stability is built right in thanks to advanced 6-axis gyro technology. The optical flow sensor actively scans the surface below, locking the helicopter into position with incredible accuracy. Together, these systems help eliminate drift, making hovering effortless for beginners and rock-solid for scale flyers.
    One-Touch Auto Takeoff and Landing
    Takeoffs and landings are no longer stressful! With the press of a button, the MD-500 lifts smoothly into a steady hover or touches down with precision. These auto functions handle the hardest parts of flying for you, so you can focus on learning control and enjoying the flight. Even first-time pilots can look like pros right out of the box.
    LED Lighting for Scale Presence
    Integrated LED lights boost realism and keep the Defender visible in all conditions. They add to the scale look of the helicopter while making orientation easier, whether flying indoors or outdoors.
    • Completely ready-to-fly package includes everything needed to start flying -- simply charge the battery, insert 4x AA batteries into the transmitter and fly!
    • Finely detailed scale fuselage replicates the MD-500 Defender with beautifully molded panel lines and rivet detail
    • Factory-applied camouflage finish with optional scale shark mouth art decal set allows for authentic scale realism
    • 6-axis gyro stabilization ensures smooth, stable flight in all conditions
    • Optical flow positioning system locks the helicopter in place when hovering
    • One-touch auto takeoff and landing functions simplify operation for new pilots
    • LED lights improve visibility and enhance scale presence
    • Scale 4-blade flybarless main rotor blade system
    • Durable rotor head and tail rotor system ensures reliable performance
    • Factory-installed servos, main motor, and flight controller for quick setup
    • USB-C charging system for convenient charging from computer or power bank
    • Reliable 2.4GHz control system ensures strong, interference-free connectivity
    • Lightweight yet robust construction designed for everyday flying durability
    • Spare tools and accessories included to keep your MD-500 mission-ready
    • RotorScale MD-500 Defender 120 Size Helicopter
    • Factory-installed motor, ESC, and stabilization system
    • 2.4GHz 6-channel transmitter
    • 2S LiPo flight battery
    • USB balance charger
    • Tools and accessories for maintenance
    • Detailed instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Class / Size 120 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 238mm (9.4") X 102mm (4.0”) X 92mm (3.62")
    Flying Weight 99g (3.49 oz)
    Main Rotor Diameter 256mm / 10.0"
    Main Rotor Blade Length 114mm /4.48”
    Tail Rotor Diameter 52mm / 2.0"
    Tail Rotor Blade Length N/A
    Tail Drive Type Factory-installed brushed motor
    Cyclic Servos 2g digital metal gear servos
    Tail Servo N/A (direct drive system)
    Power System Factory-installed brushed motor
    Electronic Speed Control Integrated ESC
    Recommended Battery 2S 350mAh LiPo battery (Included)
    Battery Compartment Size (L x W x H) 39mm (1.53”) X 28mm (1.1”) X 15mm (0.59”)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time 10 minutes or less
    Recommended Environment Indoors/Outdoors
