I have a flite line P38. The ESC's are messed up. I just purchased the programmer to re-set them. Do I do them one at a time or should I do both at once ?
Programming
Ok so I re-set everything with the programmer. I am using Futaba 6j radio. I still think something isn't right. From half stick to all the way down I have nothing. I have tried everything thing I know. From half stick up everything works fine. I have tried adjusting throttle trim, sub trim and EPA. I feel that I should be getting lower RPM and also think that the high end could be higher. I'm ready to dump these ESC's and replace them. Any thoughts on a good 60amp controller without BEC.Comment
