1.VOLTAGE
Lipo battery cells have a nominal voltage of 3.7 volts per cell.
If a model named a 3 cell (3S) 11.1 volt battery – lets just say that is what has to be used.
2.CAPACITY
Capacity indicates how much power the battery pack can hold in milliamp hours (mAh). This is just a fancy way to say how much load or drain (measured in milliamps) can be put on the battery for 1 hour at which time the battery will be fully discharged.
3.C Rating(DISCHARGE RATE )
Discharge rate is simply how fast a battery can be discharged safely.
4.Safety Instruction
Many people ignore the label, the battery was soon broken.
If you need your battery life longer, you must use it as the label says.
2.CAPACITY
.png)
