2200 Vs. 2600v
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    2200 Vs. 2600v
    What is the difference between a 2200 45c 3s and a 2600 30c 3s? Will I gain anything by going to the 2600 30c? Thanks, Doc
    Doc..........Here's how I like to explain this stuff to folks without getting into the electrical theory jargon.
    Think of the mAh rating as the size of the gas tank and the C rating as the size of the carburetor.
    In your example the 2200 is capable (per the math) of 99A (2.2Ah x 45) and the 2600 is 78A (2.6Ah x 30)
    So the 2200 will be able to power a higher amp hog for less flight time whereas the 2600 gets a little longer time but can't be used on a more demanding power system.
    The mAh ratings are pretty accurate industry standards but the C ratings are mostly overrated by 25%
    30-40C will suffice to power most prop driven birds but the EDF's want 45C and up.
    That's basically it in a nut shell.;)
    • doctormike
      • Oct 2013
      • 1260
      • Santa Fe NM
      Thanks! Doc
